    Aug 2008
    Greece
    Hi again ! i have created an .swf file using adobe flash cs4. the problem is there is space on top and bottom of the movie which i dont want. i just wants to display the movie playing which is Width="1000" Height="270".. i had set that in Flash properties, but i am getting that space above and bottom of the movie. please help its urgent.... Thank you very much...Regards
    Edit: ok when i save in quick time or avi format there is no space...it is fine... what i am missing in swf format plz help.
    Aug 2008
    Greece
    Ok found the solution... topic solved...
