Results 1 to 11 of 11
    Apr 2003
    Hey guys!
    I have just order myself a nice new Sony Bravia 40" 1080p LCD TV and would like to know which HDMI cable you guys could recommend. I want to use the TV mainly for PS3 and playing blu-ray using the PS3 and also my laptop is HD DVD which also has an HDMI output.
    My budget would be about £20.
    Thanks!
  2. Member yoda313's Avatar
    Jun 2004
    The Animus
    I wouldn't buy a monster cable for sure.
    They are mostly overhyped. Though I'm sure technically there is some quality to be gained from it - or at least less intereference potentially.
    Basically I just use anything. THey all work good. Though maybe using a total no-name cable might be best to avoid that.
  3. Member zzyzzx's Avatar
    Baltimore, MD USA
    Around here, mail order HDMI cables are really cheap. I really don't think brand matters, as long as you stay away from dollar store HDMI cables (if they exist).
  4. Member lordhutt's Avatar
    Jun 2004
    www.monoprice.com
    Cheap and work great
  5. Член BJ_M's Avatar
    Jul 2002
    Canada
    +1 for monoprice
  6. Anonymous
    Guest
    cheapest one
    Actually, I find SUPERMEDIASTORE to be cheaper on cables. $5.99 shipped for 6-foot cable.
  8. Член BJ_M's Avatar
    Jul 2002
    Canada
    $4.87 shipped for a 6 foot from monoprice .... HDMI 1.3a Category 2 Certified Cable 28AWG - 6ft w/Ferrite Cores and Gold Plated Connectors with COPARTNER brand UL certified cable bodies
  9. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    ^^^yup and monoprice even has cheap ass specials on hdmi cables sometimes under $2.00 for a 6ft.
  10. Knew It All Doramius's Avatar
    Apr 2004
    If only I knew
    Just an FYI - the quality isn't gonna be affected unless you're going long distances or have heavy magnetism or really strong AC signal near the cable. Anything 4'-10' for the cheapest price should do, as long as you're not butting 2 cables together. The more connections you add also can affect the quality.
