I have a Canon point and shoot camera which also takes video. I'd like to share alot of the videos with family members however, some of the video files are upwards of 120MB+.
I was wondering what you guys share these videos with family across the internet? Do you convert them? Upload them somewhere? (I would prefer to share these videos privately and not put them on the internet for the general public.)
TIA!
EDIT: the format of the files is AVI.
Results 1 to 10 of 10
How silly of me not to tell you what format the files are in, they are in AVI format. Sorry about that.
Upload and share them via, say, Mediafire. You can give the link to your family members.
If you want to play MP4 files on a PC, you can do a lot better than Quicktime. Get CCCP.Originally Posted by MOVIEGEEK -
I read that but I thought all still cameras used MP4 or AVCHD, use MediaInfo to make sure.Originally Posted by scormodo
Whatever the format DVDFlick can convert it.
BTW:120MB is huge for streaming, you can reencode to a lowerbitrate/resolution to make the file smaller. It all comes down to what you want:quality or small file size. -
I ran MediaInfo on one of the files, here's the results:
- Format : AVI
FileSize/String : 29.8 MiB
Duration/String : 16s 567ms
OverallBitRate/String : 15.1 Mbps
Mastered_Date : SAT AUG 29 10:35:41 2009
Encoded_Application : CanonMVI06
Video
ID/String : 0
Format : M-JPEG
CodecID : MJPG
Duration/String : 16s 566ms
BitRate/String : 15.0 Mbps
Width/String : 640 pixels
Height/String : 480 pixels
DisplayAspectRatio/String : 4:3
FrameRate/String : 30.000 fps
Resolution/String : 24 bits
ScanType/String : Progressive
Bits-(Pixel*Frame) : 1.626
StreamSize/String : 29.6 MiB (99%)
Audio
Format : PCM
Format_Settings_Endianness : Little
Format_Settings_Sign : Unsigned
CodecID : 1
CodecID/Hint : Microsoft
BitRate_Mode/String : Constant
BitRate/String : 88.2 Kbps
Channel(s)/String : 1 channel
SamplingRate/String : 11.024 KHz
Resolution/String : 8 bits
StreamSize/String : 178 KiB (1%)
Interleave_Duration/String : 975 ms (29.24 video frames)
Interleave_Preload/String : 1000 ms
What do you guys convert your files to? How much will it shrink the file? How will the conversion effect the quality? - Format : AVI
MJPEG is extremely inefficient at compression, but converting it will reduce the quality further. If you're alright with uploading the current sizes, you could just do that.Originally Posted by scormodo
If you have a lot of video to upload, you might consider doing a conversion to a more efficient format. It will cut the size to 10-30% of the original, depending on the codec and quality level you choose.
I recommend Xvid4PSP, which allows you to convert to a variety of formats. x264 is the most efficient, and XviD isn't a bad choice if you want to make playback easier.
edit: WMV is simple and playable on most computers, so I guess it isn't a bad choice either -
What do you use to reencode?Originally Posted by MOVIEGEEK
Other than Mediafire, are there any other sites you recommend? -
Originally Posted by scormodoedit: I guess you hadn't seen his reply yetOriginally Posted by MOVIEGEEK
How to recover large AVI file after formatting digital camera memory card?
By 2Bdecided in forum RestorationReplies: 2Last Post: 5th Aug 2011, 12:01 -
SD Video Camera Vs. HD Movie Mode on Digital Still Camera.
By CP/M User in forum Newbie / General discussionsReplies: 20Last Post: 20th Nov 2009, 14:57 -
.mov files from digital camera incompatible with QuickTime 7
By DavidCasillas in forum MacReplies: 34Last Post: 21st Nov 2008, 09:56 -
Baffled - Playing AVI video from Digital Camera on Blu-Ray????
By Jules070603 in forum Newbie / General discussionsReplies: 3Last Post: 25th Aug 2008, 13:46 -
MOV to MPEG or AVI from digital camera video
By mtsalmela80 in forum Video ConversionReplies: 1Last Post: 19th Mar 2008, 16:24
