    Nov 2007
    I use mpg2cut2 to extract some video clips from a vob file. these clips come out in mpeg2 format. then I use dvdflick to authorize a dvd. dvdflick can not accept 1 clip due to "corrupted or invalid format". I ran a check, this clip can be watched with vlcplayer. How can I fix the problem. Thank you.
    Oct 2005
    666th portal
    i'd try converting the vob to mpg first with vob2mpg then cutting it to see it it might help. if not restream might fix it.
