Hello videohelp forums members, Im new to this and could use some help please! Ive searched but cannot find a solution to this problem Im having.
Plugging the camcorder into a fresh install via firewire and the PC is not finding all the drivers.
Device Manager > Imaging Devices AV/C Subunit (has an exclamation mark)
when I right click that and select "update driver" a hardware update wizard starts and clicking "next" to "install the software automatically (recommended)" results in:
There was a problem installing this hardware:
sony DV camcorder
An error occoured during the installation of this device
Any ideas folks?
Also tried to "update driver" and "reinstall driver" with XP Pro CD in tray with same result.
Is the camera detected?
There is no driver to install normally. IEEE-1394 and DV format are supported natively by XP. Try a capture with Windows Movie Maker.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Formatted PC to SP2 turned off PC, plugged in camcorder, switched it on to 'VCR' turned PC on and after windows had loaded the detection and all that worked. Have been successful with capturing a tape onto hard drive.
I've had no problem with DV capture using SP3.
Analogue to Digital Capabilities on Sony DCR-PC MiniDV Series ???
By darito in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 22Last Post: 20th Apr 2012, 23:30 -
Cloning WinXP Pro 32-bit SP3 partition from HDD to SSD
By PartingShot in forum ComputerReplies: 6Last Post: 13th Dec 2011, 04:00 -
WinXP SP3 Problems
By bevills1 in forum ComputerReplies: 5Last Post: 1st Aug 2010, 23:48 -
Sony dcr h26 - how to capture contents of miniDV
By siopawman in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 3rd May 2008, 04:16 -
anyone else install winXP sp3 yet?
By aedipuss in forum ComputerReplies: 5Last Post: 25th Apr 2008, 12:01
