Hi all,
In my early encoding days, I often face the audio sync problem when converting a blu-ray to something that is playable on my hard disk. With much trial and error, I managed to get rid of this problem but now I'm facing something I've never seen before...the audio is not sync when playing the blu-ray disk!
Audio was lagging behind with power dvd and media player classic (when loading directly the m2ts files). So I decided to give it a try with upgrading power dvd and it solved the problem for power dvd, no audio problem anymore but I'm still facing the audio delay with media player classic. What could be the problem? It looks like it's a software problem as power dvd now works with an update but are there any updates/plugins for media player classic I should use ? I'm using Media player classic 64 with build 1.2.908.0, mpc compiler VS 2008, ffmepg compiler GCC 4.4.0.
Ripping the disc "as is" on my hd doesn't solve the problem either.
thanks
Try instead media player classic home cinema, latest version just released a few days ago.
well, well, well, Baldrick you are like a never sleeping oracle
I checked for an update less than a week ago and there was nothing. With the new version, I don't have my audio sync problem anymore
thanks
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 22:09 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 08:54 -
audio sync issues after converting mkv to iso and burning to bd-r/dl disc..
By landocass in forum Newbie / General discussionsReplies: 1Last Post: 26th Jul 2010, 16:03 -
Scratched disc - VOB ok but AVI out of sync
By Spoondog in forum DVD RippingReplies: 1Last Post: 3rd Nov 2009, 10:47 -
SOLVED: Audio out of sync or no audio - mkv/h.264 to avi/xvid
By dwoozle in forum Video ConversionReplies: 3Last Post: 2nd Feb 2009, 17:14
