edDv, it's me again. We have been in a long debate about what camera we needed to get. I was told last night that these certain things need to be on it. I am not the one taking the video but the one that gets to do a lot editing etc. with it though. Anyway I was told it has to have an external mic output. They said because other people will be using it they want it to be flash memory or hdd. They don't want to buy anymore tapes. They also want a quick burn option like some sony handycams have. They say some of the people using don't want anymore than to burn it to dvd and that is it. I know edDv what you are going to say but as they said I am not paying for it they are. If that be the case what would you use? You don't know how thankful I am to help someone like you to help me.
Results 61 to 71 of 71
If they want flash memory, they need to budget higher than $700. 1/3" sensor Canon models sell for more than $1000. You will also need to budget $129 for Cineform NeoScene for your Vegas Pro and/or a $250 version 9 upgrade. Then you need to budget Level 4 flash cards (78Min) at ~$32 each. Also hard drives for backup.Originally Posted by ingeborgdot
It seems they control the money, they need to cough up another $700 to $1000 to get a full solution plus the added labor for conversion.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
But they are dictating the purchase spec.Originally Posted by ingeborgdotRecommends: Kiva.org - Loans that change lives.
It's never easy.
I worked at a place where I couldn't even get them to buy some headphones and replacement PC keyboards.
"Quality is cool, but don't forget... Content is King!" -
If they don't care about image quality, just buy a casual consumer model. If they're looking at convenience factors and budget, then something's gotta give. Sanyo Xacti VPC-FH1 @ $343, for example.
edit: or maybe one of the Sony DVD-Handycams would be more suitable, but those have very limited space/recording time (since they burn to 1.3GB DVDs), and are SD only AFAIK. -
give up and tell them to go buy themselves whatever they want. and when it doesn't do the job, just smile.
When they buy what they want, play dumb and ask them to demo how it is supposed to work including the edit.
Great dumb look!Originally Posted by ingeborgdot
Now, let's look double dumb
or dumber, like:
Also needing help for buying a new camcorder
By CityTop in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 10th Jan 2011, 17:05 -
needing codecs?
By 2mmy in forum Software PlayingReplies: 3Last Post: 22nd Mar 2008, 12:27 -
Needing a Video Editor for PC
By designbuyers in forum Newbie / General discussionsReplies: 14Last Post: 20th Feb 2008, 03:07 -
needing help with HD movies
By mahfuz in forum Newbie / General discussionsReplies: 0Last Post: 6th Oct 2007, 08:57 -
Needing a new Burner
By Burn it up in forum DVD & Blu-ray WritersReplies: 6Last Post: 21st Jul 2007, 23:52
