im have downloaded a load of music videos from kazaa all play fine on the pc,but when i burn them with nero,they wont play on my dvd player,1 or2 will buy=t mostly they freeze or jump,bascially unwatchable,when i go to burn nero gives me the option to encode them,but does not do anything,says 100% encoded,but does not burn(just freezes me thinks).
i try to encode the mpeg files within nero but when i bring up the encoding option it shows no files,what is going on,i have also tried to encode them with tmpgenc but to no avail,am i just stupid or is there something amisss here.
go on give a newbie a chance
by the way i downloaded instant cd,and keep get the same error when i try to burn my vcd,it reads:Checked file : C:\Program Files\KaZaA\My Shared Folder\Linkin Park - Points Of Authority.mpeg
Invalid Rate_Bound 3512
Invalid fixed_flag or CSPS_flag
The parameters of the file you are attempting to use do not comply with the VideoCD specification.
Recommendation:
If you are sure that the MPEG2 file is not corrupt and within the specifications of the target system you can click on Ignore to continue and use the specific MPEG2 file.
Otherwise you should create an MPEG2 file which complies with the standard. Some MPEG2 creation utilities allow MPEG2 files to be created according to the Super VideoCD standard.
This option should ALWAYS be used when creating MPEG2 files to be used in InstantVideo for creating a Super VideoCD.
can anybody shed some light on this.
i also downloaded monsters inc,but that play very well on my dvd playergo on give a newbie a chance -
[quote="aberboy0"]
Recommendation:
,this happens with all my my music downloads -
Originally Posted by aberboy0
I suggest you use this site to education yourself on what the VCD specs are.
buttons on JVC XV-N50 dont work
By schlep in forum DVD & Blu-ray PlayersReplies: 5Last Post: 11th Jan 2012, 22:59 -
Trouble with audio from mobile. Used to work fine. Dont know what happned.
By UmmAddan in forum AudioReplies: 5Last Post: 6th Jan 2010, 09:13 -
Restored videos dont work!
By BVG in forum Video Streaming DownloadingReplies: 5Last Post: 7th Jan 2009, 19:50 -
DVD menus and RTMs dont work right
By shashgo in forum Authoring (DVD)Replies: 0Last Post: 20th Dec 2008, 12:54 -
Remotes dont work under MCE 2005
By Annex in forum Media Center PC / MediaCentersReplies: 3Last Post: 12th Jun 2007, 07:30
