How do I change frame rate by program MKVtoolnix![]()
want to explain the pictures![]()
1) click add to add the video
2) highlight the video track
3) click on format specific options tab
4) use the drop down menu under FPS, select your frame rate
5) press start muxing
highlight the audio track, format specific options tab, enter the stretch ratio (use inverse of the fraction by what you changed the video, i think)
e.g. it might be 23976/25000 or 25000/23976 , etc.. depending on what you changed the video by
MKVExtractGUI-2 vs MKVToolnix
By jandor2009 in forum Video ConversionReplies: 7Last Post: 6th Jan 2012, 20:06 -
MKVtoolnix issue
By hbx2006 in forum Video ConversionReplies: 11Last Post: 16th Dec 2010, 12:29 -
MKVToolnix merging help
By SunnyHours in forum MacReplies: 7Last Post: 2nd Dec 2010, 16:39 -
MKVtoolnix
By jjis in forum Video ConversionReplies: 0Last Post: 28th Nov 2010, 13:41 -
MkvToolNix Help....
By theninger in forum Video ConversionReplies: 9Last Post: 25th Aug 2008, 09:47
