Some months ago I found an easy way to copy a track from a CD with one of the tools in Subject. I've since forgotten the details. It could be I used something else, but those are tools I normally use. Is it possible with one of them? If not, what tool will? Audacity? I vaguely recall hitting some sort or target-like record button.
I want to copy the track, then put it in wav or some audio format, and send it off via e-mail.
Results 1 to 9 of 9
most likely the track would be way too big to email if left in wav. use any of those tools and rip to mp3.
Yes, but that's an easy problem to take care of. Another format, or using different lower quality properties.
a .wav is a .wav, there are no "lower quality" settings. it has a fixed bitrate.
wav or whatever is beside the point. The question is how to perform the operation simply using some s/w tools. I have I have to chop it into segments, that'll be fine with me. mp3 -- whatever.
T'was easy. SoundForge File->Extract Audio from CD. Save As each track with 16kpb for MP3 gives 870K. Easy fit for e-mail of many tracks each 7.5 minutes long, or combine them into something less than 10M.
Not true. WAV is a container file that accepts uncompressed, losslessly compressed, and lossily compressed codecs/algorithms. Not even counting MP3-in-a-WAV, etc., you could, for example, take the same ripped CD master track and either leave it alone at is native state of uncompressed, stereo LPCM @ 16bit and 44.1kHz (1.346Mbps), or you can downsample and downconvert it to 8bit, 22kHz, mono ADPCM at ~1/24 the bitrate.Originally Posted by aedipuss
I'd recommend you get EAC and then choose the exact codec as your external compression type (mp3, flac, ogg, etc) and then be able to automatically get BEAUTIFUL copies of what you want, with minimal fuss...
Scot -
sorry, was only considering cd audio wav, which only comes in one flavor.
another decent audio ripping/converting tool is dbpoweramp.--
Vegas 11, multicamera track only rendering to one video track
By CursedLemon in forum EditingReplies: 0Last Post: 29th Feb 2012, 03:11 -
Sony Vegas 7: Where's the video on the track?
By cstar7777 in forum EditingReplies: 3Last Post: 24th Mar 2011, 18:29 -
Was I supposed to get soundforge 10 with Vegas 9.0?
By solarblast in forum AudioReplies: 0Last Post: 13th Mar 2011, 22:50 -
Splitting Track Problem in Vegas
By duderdude2 in forum EditingReplies: 2Last Post: 23rd Feb 2010, 15:55 -
Where is the Video event(/Track) FX timeline in Vegas 7.0?
By mobobo in forum EditingReplies: 5Last Post: 31st May 2007, 03:33
