I usually use DVD Shrink to burn my videos. Lately I decided to use imgburn. When I do, when it checks for errors, I get errors every second. Says over 22 hours left on checking. I stop the error checking.
The DVD's play on my DVD Player.
Why does Imgburn give so many errors? What's going on?
Thank you,
Chris.
				Results 1 to 21 of 21
	The imgburn post-burn verification algorithm conflicts with DVD decryption such as AnyDVD. You need to temporarily disable any decryption software before using imgburn, or its error verification will go bananas after the burn. Alternatively, if the disc being burned is not vital or irreplaceable, just disable imgburns verification feature until you really need it. Otherwise, you might have some other software conflict going on: even with really bad media, you would not get a readout saying "this entire disc is nothing but errors" like you're seeing. ImgBurn makes fantastic burns, perhaps the best, its just the post-burn error verification system can get stymied by other software you might be running in the back ground. If thats disabled, ImgBurn's error verification will almost always work perfectly. If all else fails, use other software to check for errors afterwards and you'll probably find the discs are perfect.
	hech54
 I burned an awful lot of DVD's using DVD Shrink. Back when the code was written Nero was really the only burning software worth having. So dvd shrink was written to use nero if you told it to. That made the dvd rip and burn all one process. Never say never.
 Reelman472
	Just to clarify: DVD Shrink had a feature that turned the burning process over to Nero, but DVD Shrink did not do the burning itself. (There is a mod version of DVD Shrink that can launch ImgBurn as well.)
 You did not describe your source video. I suspect the errors are a copy protection issue. (DVD Shrink has not been updated in a long, long time and cannot handle newer copy protection.) Better to rip to hard drive with DVDFab. If copy protection is not the issue, then the problem would most likely be with your disc media. You did not mention the brand of blank discs you use, but if you are not using either Verbatim or Taiyo Yuden, you are asking for headaches.
	No you didn't....DVDShrink does not and never did burn anything.Originally Posted by Reelman472
	Hech54 knows this.Originally Posted by Reelman472
 2nd, no NERO was NOT the only burning software worth having
 Shrink was written to utilize DVD Decrypter which was a much better program to burn dvd's with.
 But Hech54 is correct, DVD Shrink NEVER burned to disc's!!
 It had an OUTSIDE program do the actual burning.
 Nero or DVD Decypter.
 As for the OP's question, hard to say seeing as you have provided absolutely ZERO information!
 What was the original source ?
 What type of dvdr's are you using ?
 Ect. ect. ect. ect.
	I tried to play the disc in my home theater. "Cannot Play Disc" message.
 I thought heck with this crap (imgburn). I *Burned it in DVD Shrink and it plays perfect.
 *If I open DVD Shrink, it goes through the process, always showing DVD Shrink, I call that Burning with DVD Shrink. Even tho it borrows nero to do the actual burning.
 Thank you for the reply's,
 Chris.
 P.S. If you have trubble using Imgburn, remember, it sucks.
	The most common sources of trouble are dodgy media and newbie pilot error, not the software. Imgburn is widely acknowledged as vastly superior to Nero, so your PS is BS. It's much more likely that you used bargain-brand media, or touched the surface of the disc prior to burning, or accidentally burned as data, instead of as DVD.Originally Posted by happydog500
	Noahtuck,
 If you read what happened, you seem not to really know what your talking about.
 Maybe you didn't read my post, or got it mixed up with a different one?
 Oh, yea, maybe the media I'm using for the last year is the problem.
 Chris.
	Originally Posted by happydog500I'm confused! Are you complaining about verify errors on discs that still work, or don't they work?Originally Posted by happydog500
 Use Shrink to generate an *ISO* file (not VIDEO_TS folder), and burn that with ImgBurn...this will ensure the disk is generated with the correct filesystems (ISO9660+UDF)
 Trev
	I KNEW there was a reason I was rude and dismissive to your original post...you really ARE an idiot.Originally Posted by happydog500
 Next time when you decide to blindly bash the best burning software
 ever created...spray paint it to a wall somewhere where you won't get
 picked apart instantly by intelligent people.
	Tard say's what ??Originally Posted by happydog500
 Sorry, i just can't take or respond to clueless morons intelligently.....
	Please keep this thread civil or it will be locked.
 Moderator redwudz
	Pull! Bang! Darn!
	Buy better discs. That would likely fix it! Want my help? Ask here! (not via PM!)
	Never argue with a fool and never feed a troll.
 As to the original question: turn off verify and use better media.
  I/O errors using ImgBurn and DVD DecrypterBy jcsdmd in forum Newbie / General discussionsReplies: 16Last Post: 27th Aug 2011, 15:58
  Nero vs ImgBurn: Why is ImgBurn preferred?By usually_quiet in forum Authoring (DVD)Replies: 31Last Post: 28th Aug 2010, 18:47
  svcd preview errors & vob file errorsBy kiwi76 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 10th Nov 2008, 17:02
  check a DVD for errors/read errors?By ebob in forum Authoring (DVD)Replies: 4Last Post: 5th Jun 2007, 11:53
  Upgraded to ImgBurn 2.2 - Now "ImgBurn Shell Ext" No Longer WorksBy Cool Breeze in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 11th May 2007, 11:05
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
			 Visit Homepage
				Visit Homepage
