when i play 1080p movies on my PC it has low FPS and many lost frames, you can also notice a lot of jumps.
my graphics card is 7600GT, my processor is C2D E6300 (1.86Ghz).
i'm using Windows 7 64 Bit RC, but the problem was also on Vista 32...
i'm using VLC Media Player and Windows Media Player.
Results 1 to 18 of 18
Originally Posted by jagaboSo, i have to use another player, with one of this 4 mt codecs?Originally Posted by drjtech
i forgot to mention that 720p movies are playing correctly. -
Personaly I use Win7 64 bit
It supports things like deep colour which xp and vista dosnt and is far better at High def
I like things like Klite codec pack. VLC has a bad tendacy to stuff up and confuse my computer
Keep things simple just use Klite with Mediaplayer Homecinima which is free and better than anything i have payed for.
Hint uninstall VLC and anything else you may have first -
1080p takes more CPU power than 720p (at the same frame rate).
VLC uses only its internal decoders so there's nothing you can to to fix that.
If you install ffdshow mt, Divx7, or CoreAVC Pro WMP will use that h.264 decoder and you should get smooth playback of 1080p.
MPCHC has its own internal multithreaded h.264 decoder. You can elect to use an installed DirectShow decoder instead if you want. If your graphics card has hardware h.264 decoding (your 76000 GT doesn't) you can elect to use that too. -
Your CPU is too weak. To handle 1080p, overclock your Core2 Duo to 2.5 GHz or buy a Core2 Quad.
A C2D E6300 will have no problems playing a 1080p24 or 1080p30 h.264 video as long as a multithreaded h.264 decoder is used.
Yes it's better (faster)Originally Posted by creamyhorror
Scroll down and see the #'s
https://forum.videohelp.com/topic362188.html -
That GFX card and CPU combination should be enough to play H264/1080p smoothly when using DXVAOriginally Posted by fussgen
Check this site how to set this up correctly:
Watching h.264 videos using DirectX Video Acceleration (DXVA)
Even with a simple NVidea 6100xl card which only supported basic DXVA (scaling,deinterlacing) I was able to play h264/1080p with a old P4 3,2 smoothly. -
I thought h.264 decoding started with the Nvidia 8000 series. Ah, the 7600 GT has some h.264 decoding but doesn't support IDCT and CAVLC/CABAC (which started with the 8000 series):
http://www.nvidia.com/docs/CP/11036/PureVideo_Product_Comparison.pdf
It's worth a try. In MPCHC go to View -> Option -> Internal Filters -> Transform Filters and enable H264/AVC (DXVA). Exit the program then restart it. -
As said, you don't need to have a GFX card with full H264 decoding abilities to take advantage of the hardware acceleration features.Originally Posted by jagabo
At the moment I am using here a GeForce 7300, using the DXVA features of that "simple" card will reduce the CPU load immensly when playing HD files or watching live HD TV with my DVB-C card. -
now it's all good !
first of all, i installed the CoreAVC, and then it was much better while i was watching the movie on Windows Media Player.
VLC still couldn't handle the movie because there was no change for it.
after my OC (C2D E6300 1.86Ghz @ 2.33Ghz), even the VLC played the movie smoothly.
Shrinking 1080p MKV, change to 720p or keep as 1080p?
By Phat J in forum Video ConversionReplies: 5Last Post: 28th Nov 2010, 10:35 -
I keep thinking this can't be right - 7gb for 1080p? Harry Potter movies
By AndyD in forum Blu-ray RippingReplies: 7Last Post: 17th Oct 2010, 09:45 -
1080P Playback On My PC? And WD 1080p Player Need A Expert!
By wpittsen in forum Newbie / General discussionsReplies: 2Last Post: 30th Sep 2009, 13:43 -
HDV 1080p Im Looking for 1080p HDVs.
By ChristianPaprika in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 19Last Post: 16th Nov 2008, 22:05 -
how to remove heavy noise in video?
By Driftking978 in forum Newbie / General discussionsReplies: 5Last Post: 26th May 2008, 05:24
