Hi,
I've done some work with recoding video to DVD before and did what I think is a pretty high quality job (complete with repeating menu music and lightscribe labels) but I met my match in a slideshow.![]()
A friend of mine performed an original song at our car club's national show this summer and I've been making a slideshow of images from the show timed to his song. Unfortunately, the maximum file size that can be hosted on our club website is 60 MB and I can't seem to get the video down to that size without sacrificing the timing.
I'm using Nero to do the photo show.
Here's the slideshow with the default settings.
In order to get the file size down below 60 MB I have to change the format from NTSC to PAL and reduce the bit rate (from ~1850 to ~1700). If you compare the end of the first video (where the black car appears) to the end of this video you can see that the timing is quite different.
Is there anything I can do to reduce the file size without sacrificing the timing? There are a couple other file type options in Nero but MPEG-1 seems to produce the smallest file (unless I'm missing something).
Thanks!
File size = bitrate * running time
Remake the slideshow video with a lower bitrate. -
What video format is used most as a playback format on the club's site? As jagabo said, you can go with a lower bitrate in MPEG-1 (though DVD format is MPEG-2), or you could go with more compressed formats like flv (which is what YouTube plays) or Xvid. Those will save disc space. Also, a lower frame rate (like 15fps) would make a smaller file size.
Just a side note: If you ever plan to also distribute the video on disc to DVD players in the US, you cannot encode to PAL. Stick with NTSC. -
jagabo,
Unfortunately, with the bitrate minimized in NTSC the file is still too large for hosting from the website.
The "good" bitrate is 1841 kbps. That's the minimum that Nero allows for MPEG. I don't know if it's the reduction in bitrate or the change from NTSC to PAL that is destroying the timing.
filmboss,
I don't think there are any videos currently hosted from the website (except maybe some drag videos in member galleries). I believe flv and Xvid are options, but I didn't use them because they were unfamiliar to me. I'll try recoding it in flv or Xvid tonight.
Thanks for your help guys! -
Originally Posted by GearBeer
Depending on how you set up the slide show and how it was converted from NTSC to PAL, the timing could be affected by the frame rate change.
PowerDirector makes final DVD files, size larger than mpg file's size, why?
By Xor2 in forum Authoring (DVD)Replies: 4Last Post: 22nd Dec 2011, 17:29 -
mpg file size smaller than expected, TMPGEnc 2.5 VBR 2-pass mode
By chipsndukes in forum Video ConversionReplies: 1Last Post: 22nd Dec 2008, 20:48 -
mpg to dvd keep file size
By bladerunnerx_x in forum Newbie / General discussionsReplies: 10Last Post: 9th Sep 2007, 13:12 -
Reducing mpg file size
By sknox in forum MacReplies: 2Last Post: 3rd Jul 2007, 04:41 -
File size problem with TMPGEnc [.avi to .mpg conversion]
By Timex in forum Video ConversionReplies: 7Last Post: 26th Jun 2007, 21:50
