I need a software that can convert FLV's i have them in 6parts.
I need to be able to Merge them properly
then i need to convert it to AVI format.
I use flv extract already,
gave me an AVI(FLV) and mp3
i mux it with virtualdubmod.
same with other parts but when i try to append
1/6.avi
2/6.avi
i get different sampling rate....
i also did use a software to load all FLVS and convert it to WMV by its out of sync half way. (FormatFactory)
need help how to do this properly, without out of sync.
Code:http://www.youtube-pinoy.com/files/20081107-hihintayin%20kita%20sa%20langit%20p1.flv http://www.youtube-pinoy.com/files/20081107-hihintayin%20kita%20sa%20langit%20p2.flv http://www.youtube-pinoy.com/files/20081107-hihintayin%20kita%20sa%20langit%20p3.flv http://www.youtube-pinoy.com/files/20081107-hihintayin%20kita%20sa%20langit%20p4.flv http://www.youtube-pinoy.com/files/20081107-hihintayin%20kita%20sa%20langit%20p5.flv http://www.youtube-pinoy.com/files/20081107-hihintayin%20kita%20sa%20langit%20p6.flv
Or if that wont work try join using Andys FLV Joiner and then convert.
I found a great program that converts to almost any format and it does it quickly. I mainly use it to convert my videos to XVID for the XBOX classic (XBMC) and XBOX 360. I have tried others and they were either very slow or did not work as well as this program. The web site is www.Oxelon.com and best of all the program is free!
You will need to download the program and the plugins.
Raymond -
I just saw that you needed to merge the videos. If you don't have a video editor available you can convert your videos to VOB's then use VOBmerge (a great free program) to put the videos together then convert them to FLV.
The Oxelon software has a feature called "Direct Stream Copy" which does not recompress the file but puts the file in the new format (The directions say this is quicker then recompressing the file) I have not tried this feature yet.
Raymond -
Originally Posted by Baldrick
I downloaded version 0.3, but when trying to open the first Flv file (downloaded with latest version of Youtube downloader), I receive an error that it is not an FLV file. The files play with no issues with FLV Player and Riva's FLV Player.
How to convert FLV videos and resize them to convert them to AVI
By zikegi in forum Video ConversionReplies: 2Last Post: 17th Sep 2011, 23:06 -
which software works best for flv to dvd can i convert dvdor flv to divx
By rugrat23 in forum Video ConversionReplies: 2Last Post: 19th Jan 2011, 12:39 -
convert x not working properly
By paullyon in forum Newbie / General discussionsReplies: 3Last Post: 24th May 2010, 09:41 -
How to properly convert interlaced MPEG to AVI?
By lovyagin in forum Video ConversionReplies: 1Last Post: 12th Nov 2009, 05:34 -
Movie Clip Will Not Convert from .flv to .avi - Pazera Free FLV to AVI
By videoelfone in forum Video ConversionReplies: 3Last Post: 21st Jun 2008, 00:14
