Subtitles appear as diagonal splashes of dots rather than text.
^ That's all I get now in MPC and I don't know what has caused it. Was working fine a few days ago. It's not like I can uninstall MPC and reinstall it to fix it. I am running Windows 7 x64.
Someone help me please. :'(
Also I can't get subtitles to display in Media Center or latest version of Windows Media Player either.
In MPC go to View -> Options -> Subtitles -> Default Style. Make sure the Angle is set to 0, Scale x and y to 100. Check the font too. If subs still aren't working you may have to go into the registry and tweak things there. Unfortunately, the subtitle settings are saved as a list of numbers in one key.
HKEY_CURRENT_USER\Software\Gabest\Media Player Classic\Settings\SPDefaultStyle
MPC and MPCHC seem to use a slightly different list of numbers and can screw each other up. -
Ah, I have used the Home Cinema x64 version a few times, but found it buggy and had deleted it.
Changing the subtitles settings weren't being saved even when I ran MPC as an admin, so I deleted all the MPC preferences in Registry Editor and now MPC is working fine.
Thanks for the fine tips jagabo. Cheers.
MPC-HC not displaying properly on second monitor
By Xirix in forum Software PlayingReplies: 2Last Post: 11th Jan 2011, 12:04 -
.ts file not displaying subtitles
By Pike800 in forum SubtitleReplies: 9Last Post: 30th Nov 2010, 09:08 -
New here, I am having troubles with displaying subtitles on my pc!!!
By Luciauruguay in forum Newbie / General discussionsReplies: 3Last Post: 10th Jan 2010, 11:31 -
Subtitles displaying too early!!!!!
By NextJinGamer in forum SubtitleReplies: 0Last Post: 17th May 2008, 14:35 -
Displaying Subtitles from file on computer while playing a DVD
By mrdemanding in forum Newbie / General discussionsReplies: 4Last Post: 10th Mar 2008, 09:15
