Hi everyone, I have several short mpeg video clips (5 to 7 min.) I would like to burn on a single dvd. The problem that I'm having is the next/skip feature will not work. How can I record so that I can skip to the next video instead of watching the hole thing all over again? There will be about 15 to 20 clips on one dvd.
Thanks, justbecause
Windows Movie maker doesn't make DVDs, unless you are on Vista using Windows DVD maker.
Generally, the next button skips to the next chapter. If you have created your DVD as a series of titles (separate videos one after the other) then extra programming has to be included to get the Next button to skip like chapters. Some low end tools do this by default, some don't.
The simplest solution to put everything into a single video, add chapters at the start of each, and the Next will skip the way you want it to.Read my blog here.
TMPGEnc AW4 Chapter Head Skip button NOT working
By BobAchgill in forum Authoring (DVD)Replies: 0Last Post: 23rd Jun 2010, 10:14 -
Burn't DVDs skip 1 to about 5 frames every 30 sec. or so, please help.
By Fluffin in forum Authoring (DVD)Replies: 5Last Post: 21st Apr 2008, 11:46 -
Best way to burn a working DVD from an image
By kelman4 in forum MacReplies: 5Last Post: 2nd Apr 2008, 21:29 -
vob blanker took away 'skip' feature
By m-man in forum Newbie / General discussionsReplies: 0Last Post: 15th Feb 2008, 00:07 -
Screensaver Password Protect Feature Not Working!
By lapetite_66 in forum Newbie / General discussionsReplies: 3Last Post: 17th May 2007, 14:57
