Background: converted numerous VHS tapes to DVD with a Panasonic DMR-E85H. The DVDs were authored in 704x480.
Want to now author BluRays with this footage but BluRay only supports 720x480.
When using TMPGEnc Authoring Works 4, it will re-encode the footage to 720x480, however their is a noticeable loss in quality as I believe the footage is stretched, not to mention it takes a long time.
Is their anyway to make 704 into 720 without re-encode?
Any help would be greatly appreciated.
Results 1 to 19 of 19
Magic?
"Well, my days of not taking you seriously are certainly coming to a middle." - Captain Malcolm Reynolds -
Nope. Resizing requires reencoding.
But maybe try multiavchd and see if it suppports 704x480 and it might work on some blu-ray players. -
No, you will need to re-encode, AFAIK.
But you could add 8 pixel black bars to each side and not have to resize and save some quality. You would want to up the bitrate to take care of encoding quality losses. But why would you want to convert to BD? Any conversion will only lower quality. You won't make any improvements with the conversion.
If you just want to put more videos on the larger BD disc, just add them as data files. -
Are you certain 704x480 isn't supported by Blu-Ray? I'm almost certain it is. All SD ATSC Digital television is 704x480.Originally Posted by rogalewski
First you shouldn't horizontal scale since this will cause scaling and recode loss. Trick is to add 8 black pixels left and right to pad out to 720 horizontal pixels.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
How would I go about adding 8 pixel black bars to a DVD Video?Originally Posted by redwudz
I'm actually transferring a bunch of my DVD-R VHS converts to BD-R discs, since I can fit much more standard definition video on 1 BD-R. Around 20 hours of footage on one disc as opposed to 2 hours per DVD-R.
Thanks for the help. -
I'd do it with a 704x480i composite in a 720x480 Vegas or Premiere project but I hope others will have ways to do it in free software. My machines are tied up right now so I can't test other solutions.
This might be worth a shot. what about just patching the header to give the fake pic size of 720x480 with the old dvdpatcher tool?
AddBorders(8,0,8,0)Originally Posted by rogalewski
http://avisynth.org/mediawiki/AddBorders -
Thanks everyone for your responses.
I tried patching with DVDPatcher but TMPGEnc still recognized it as not in acceptable BluRay format.
I will try using Avisynth tonight and let you know how that works out. I plan on using Avisynth with DGIndex to edit the VOB directly. Once I open the .avs file with VirtualDubMod, how do I export the video with added borders back to a new .VOB file? Or what's the best way to go about that?
As far as using Vegas, I do have a copy at work I can use. Would you mind providing brief instructions on what I could try? I've never used the software.
One last thing, I found this in regards to acceptable BluRay video:
As you can seem, 704x480 is not listed. -
You don't. After testing the script in VDubMod to make sure it's a good script (it'll give a helpful error message if there's something wrong with the script), open the script directly in your MPEG-2 encoder. When done, take the M2V produced, together with the original source audio, and reauthor for Blu-Ray using whatever you use to do that.Originally Posted by rogalewski
Okay great, one last question: what MPEG-2 encoder should I use to convert the Avisynth script into an M2V?Originally Posted by manono
Thank you! -
HCEnc. It's free and works really well. I apologize if you already covered this as I skimmed the thread and just wanted to specifically answer this question, but I hope you noticed that you have to double the frame rate from standard def DVD for BluRay.Originally Posted by rogalewski
Your frame rate for 720x480i on Blu Ray needs to be 59.94 fps. -
Don't think so. 59.94-i in this context means 29.97 interlaced frames per sec (although in others it is sometimes used to mean 59.94 frames rather than fields).Originally Posted by jman98
You are 100% correct. My mistake. Ignore that part of my post.Originally Posted by Gavino
Ended up using Xilisoft DVD Audio Ripper and it works great.
Thanks everyone.
Help. Convert menu sublayer from 720x576 to 720x480 (PAL to NTSC)
By danfisherman in forum Authoring (DVD)Replies: 6Last Post: 9th Jan 2009, 11:56 -
Why DVD (720x480) bigger than AVI(720x480)
By psxiso in forum Video ConversionReplies: 6Last Post: 3rd Feb 2008, 05:50 -
How to convert 640x480 to 720x480 ?
By webstar in forum MacReplies: 3Last Post: 8th Jan 2008, 09:44 -
What should I do w/ Video OpenDivX4 720x480 24.975 PAL/NTSC? fix or convert
By JoeBolden in forum Video ConversionReplies: 1Last Post: 15th Dec 2007, 22:12 -
DV to 704x480 or 720x480?
By Almost Human in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 10Last Post: 11th Dec 2007, 19:37
