I tried Digizombie's hack and it worked!(method B)
It's very simple and with slight changes I made it.
This is the hack for European Philips 3350 (not V)
1) Turn on TV set
2) Turn on DVD player
3) Open tray
4) Digit 9,9,9,9 then 0 (if you want all regions)
5) "Region code : 0" appears on screen
6) turn off player
Philips 3350 is region free!
So thank you so very much to Digizombie and to all the other guys that helped with their advice.
One last thing:this is basically the same hack I used for my old Philips 625 that I bought in 2004...
Closed Thread
One topic is enough, continue in https://forum.videohelp.com/topic371721.html
LG HT805PH player: Can anyone verify if this region free hack works?
By the shutdown man in forum DVD & Blu-ray PlayersReplies: 0Last Post: 22nd Aug 2011, 14:30 -
hack for philips dvp 3350
By mlovisetto in forum DVD & Blu-ray PlayersReplies: 4Last Post: 23rd Aug 2009, 18:43 -
ext hdd works on philips not on pc
By catdaddio6 in forum ComputerReplies: 7Last Post: 23rd Feb 2009, 13:28 -
Does 1TB hard drive works on Philips dvp 5990/2
By waefwaeefwaefw in forum DVD & Blu-ray PlayersReplies: 9Last Post: 8th Dec 2008, 21:52
