hi everyone.i am in the process of using bd rebuilder to re-encode my movie only blue ray and using convertxtodvd to put the movie onto a dvd5/dvd9.so far i have burned 2 dvd5 discs but the file size after converting them is 3.2/3.3gig movies.my question is how can i get these movie files upto close to the 4.3 gigs on a dvd5 disc.i have a medium setting set up on convertx.should i adjust this to high to achieve a higher file size??thanks in advance
I don't use convertxtodvd, but may I ask why you are doing this? It seems to me that doing
BluRay -> single/double layer BluRay -> DVD
is really a lot less optimal than simply doing
DVD rip -> DVD
It makes no sense to me that you are doing this from BluRays you bought unless maybe you are making copies for cheap friends/family, so if you are downloading the BluRays from the internet, just download DVD rips instead and your life would be better. -
i am making a few back-ups of my blue rays for other dvd players in the house.this is to preserve my blue ray and so they dont get scrathed up by the kids.
If you read the comments from our tools list, https://www.videohelp.com/tools/ConvertXtoDVD , you will see that this is common. Maybe you can use 2-pass encoding and you can get more exact sizes, see https://forum.videohelp.com/topic367624.html
That's just the way it is sometimes. It you want more details spend a few hours at VSO's forums. Do try again with the 'High Quality-> Long encoding time' option. The 'problem' seems to be more of perception than of actual quality. Do note that CX2D's main objective is for is for speedy conversion of Xvids and other compressed files. Seeing as you are starting with a high quality source why not try another app better suited to the job. AVStoDVD (free) should suit your needs. Lock in 2 pass HCenc as your encoder and see how it looks. It will fill your disc and should provide a superior result... but it will take considerably longer.Originally Posted by dvd1304
PowerDirector makes final DVD files, size larger than mpg file's size, why?
By Xor2 in forum Authoring (DVD)Replies: 4Last Post: 22nd Dec 2011, 18:29 -
File size differs from data size--HUH?!
By atoledo123 in forum MacReplies: 2Last Post: 9th Sep 2011, 14:19 -
Question: MKV File Size vs MP4 File Size
By VideoNoobz in forum MacReplies: 6Last Post: 20th Feb 2010, 03:44 -
convertX waits for OK to erase DVD-RW
By lhughes in forum Video ConversionReplies: 4Last Post: 12th Sep 2008, 02:34 -
convertx to dvd
By thecrock in forum Newbie / General discussionsReplies: 1Last Post: 26th Feb 2008, 14:54
