Hello all,
Well, I've taken the plunge and am trying to create a stills-menu
(for starters) with chapters (entrypoints) XVCD with TSCV. I am using
TSCVv84r2 with an MPEG-1 source file with video at 2400kbps and
audio at 224 kbps. Resolution is standard 352x240.
I used TSCV to create chapter entrypoints every 200 seconds
in the MPEG. I also made sure to encode the MPEG with the
closed GOP setting enabled in TMPGEnc 2.02.
TSCV appears to build the still-menu correctly in the MenuGen
function, but when I try to build the BIN/CUE file I get the
following errors:
Starting VCDxBuild process...
initializing libvcd 0.7.12 [cygwin/i686]
this is the UNSTABLE development branch!
use only if you know what you are doing
see http://www.hvrlab.org/~hvr/vcdimager/ for more information
front margin set smaller than recommended (0
rear margin set smaller than recommended (0
scanning mpeg sequence item "menu-0" for scanpoints...
scanning mpeg sequence item "sequence-1" for scanpoints...
requested entry point (id=entry1-1) at 200.000000, closest possible entry point at 66.065989
requested entry point (id=entry1-2) at 400.000000, closest possible entry point at 66.065989
entry point 'entry1-2' falls into same sector as previous one!
requested entry point (id=entry1-3) at 600.000000, closest possible entry point at 66.065989
entry point 'entry1-3' falls into same sector as previous one!
writing track 1 (ISO9660)...
writing file `CDI/CDI_IMAG.RTF' (1315168 bytes, raw sectors file)
writing file `CDI/CDI_TEXT.FNT' (13616 bytes)
writing file `CDI/CDI_VCD.APP' (102400 bytes)
writing track 2, MPEG1, NTSC SIF (352x240/30fps), audio[0]: l2/44.1kHz/224kbps/stereo ...
finished ok, image created with 55058 sectors [12:14.08]
VCDxBuild finished
When I try to burn the resulting BIN/CUE I get an error stating that
the entrypoints are invalid....
Can someone tell me what I am doing wrong here? Also, TSCV doesn't
appear to report the MPEG duration correctly for hi-bitrate MPEG
even though I checked the "X" box on the main "Settings" page.
Have I missed a setting here?
Any help is appreciated. Thanks,
vcddude
Results 1 to 1 of 1
DVD FLICK, Start-up Error Msg-Unable to created txt file. Last DLL error: 5
By jacknscoob in forum Authoring (DVD)Replies: 5Last Post: 4th Mar 2012, 08:58 -
TSCV on Vista
By mrcoolekin in forum Authoring (VCD/SVCD)Replies: 4Last Post: 11th Feb 2008, 23:04 -
source filter error (Error=80040241) when playing HR Avi
By mwm in forum Video ConversionReplies: 3Last Post: 4th Nov 2007, 10:03 -
Get many error messages, AviSynth error message and meGUI error
By MKVcrazy in forum Video ConversionReplies: 0Last Post: 25th Aug 2007, 16:41
