Hi, didn't find anything relevant on the subject
What I want is to find a way how I could automatically cut out commercials in the beginning and in the end of a video file. Automatically since the same should be done for tens of videos.
So would it be possible for e.g. snap example frames (start/end point) from one of the clips, then whenever that frame appears in any of the clips, the contents before/after are deleted automatically. Is there any software to do that?
Thanks!
If you are cutting mpeg files then you could use videoredo and it ad-detective tool. It scans the file for black frames (fade in/out) and makes the cuts for you. But be aware that no matter how well you tweak the parameters it's still not exact and if you ask me it's still a good idea to scan over the file to make sure that the cuts are correct. I have the most problems with show that have lots of fade in/outs i.e. the new "Defying Gravity". I record it with my tivo and then cut the commercials with videoredo. It never fails that some of the actual show are cut out along with the commercials. Defying gravity has many fade in/out spots seperating scenes in the show. Videoredo thinks that those fade outs are the marker for a commercial.
For the most part though videoredo is probably the best you can get for automatic commercial detection. It handles most shows with no problems.
There is also a freeware program called comskip that I have never used but I do know that it requires much more manual setting than videoredo does.Donadagohvi (Cherokee for "Until we meet again")
how to author a DVD from the beginning to the end
By michcio in forum User guidesReplies: 3Last Post: 13th Apr 2012, 18:43 -
How do I rip a DVD, trim part of it (beginning & end), and copy onto DVDs?
By aple in forum Newbie / General discussionsReplies: 5Last Post: 11th Jul 2011, 19:04 -
editing video - cutting a few minutes at the beginning and end
By hardy in forum Newbie / General discussionsReplies: 6Last Post: 30th Jun 2010, 18:19 -
How do I clean up (trim) beginning and end of DVD?
By perceptionist in forum EditingReplies: 6Last Post: 28th Mar 2010, 01:29 -
Problem with end frame showing up at beginning when converting ts to avi
By mt123 in forum Video ConversionReplies: 2Last Post: 27th Sep 2009, 12:54
