im brand new to this so bear with me,
before i even get into burning a vcd, this is what i want to do,...
i have recently downloaded an mpeg music video and the 1st thing i want to do is replace the horrible audio quality.
is it possible to take my own good quality mp3 file and replace the existing audio track that is in the mpeg video?
if so, please give me some direction on what software i could use to do such a thing, and if i need to convert my existing files to something else before beginning the process.
thanks,
deadliner
Demultiplex the .mpg with TMPG http://www.vcdhelp.com/bbmpegedit.htm
Convert your own .mp3 to .mp2 with BeSweet http://dspguru.doom9.net/
Multiplex the videostream (.m1v or .m2v) with the new .mp2 with bbMPEG http://www.vcdhelp.com/bbmpegedit.htm -
Originally Posted by Truman
I mean, everytime I convert a wav to mpx (x=2 or 3), the encoder adds about 1 sec of silence at the beginning so the audio is shifted by this amount in time. -
Which audio encoder do you use? However, if it is adding 1 second of silence at the beginning, you can correct this by multiplexing with bbMPEG. At the program stream settings tab you can define the audio delay. In that case you have to change e.g. audio delay 180 to 1180.
I'm using CoolEdit with mp3 plugin (tried toolame with the same prob) and wav2mp for converting wave to mp2.
No sound when replacing audio
By konu in forum Newbie / General discussionsReplies: 3Last Post: 2nd Sep 2011, 19:10 -
help replacing audio on DVD
By fullbohr in forum AudioReplies: 3Last Post: 12th Nov 2009, 20:34 -
replacing audio on a dvd
By phillbrett68 in forum Authoring (DVD)Replies: 10Last Post: 11th Dec 2008, 00:11 -
By phillbrett68 in forum Authoring (DVD)Replies: 2Last Post: 7th Dec 2008, 01:00 -
Replacing MPEG audio.
By dfisher052 in forum AudioReplies: 3Last Post: 16th Oct 2007, 13:14
