am looking for a continuous play option
	Good luck. Maybe someone knows of a player that will do that, but I don't.
 I am posting mainly to warn you about something. Today's DVD players are designed with cheap components and they need a lot of open space for air cooling. Today's players just aren't designed to last very long. Playing discs for long periods of time will surely shorten the lifespan of any player you get. If you can find a player that meets your needs, be sure to put it in as open a space as possible so that it can cool in the air and hopefully last a while for you.
	I changed the topic subject as just dvd players doesn't say anything.
	All the ones I've used had a "repeat" function.
 Either of the whole disk or a selected section, and would keep playing it till you stopped it.
 You probably already have one that does this. So just RTFM.
	it may be cheaper and easier to just re-author the disc with a replay function... I am just a worthless liar,
 I am just an imbecil
  What to keep in mind so that the dvd will play on all players?By Srivas in forum Authoring (DVD)Replies: 8Last Post: 19th Dec 2011, 06:20
  Is there any DVD players which can play HD DivX?By kalingga in forum DVD & Blu-ray PlayersReplies: 4Last Post: 8th Jul 2011, 19:06
  GFD: continuous play in Audio TitlesetsBy AlanHK in forum Authoring (DVD)Replies: 6Last Post: 3rd Aug 2010, 16:33
  Continuous play of root menu audio throughout all menu'sBy breakbred101 in forum Authoring (DVD)Replies: 3Last Post: 28th Apr 2009, 19:37
  DVD's will only play on some players . . .?By herd72 in forum Newbie / General discussionsReplies: 4Last Post: 7th Jul 2008, 08:20
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
