I have added motion to still images in Final Cut pro but when made into quick time movie and burned the movement in the images is really blurry. How can I fix this problem?
Would really appreciate help asap.
Thanks,
Fiona
By "add motion" I assume you mean the "Ken Burns Effect" type of thing - pans and zooms across the image ?
Looks blurry in the quick time movie, or just the burned DVD ?
If it looks blurry in the quicktime movie, can you turn off Motion Blur in FCP (assuming it has such a setting - most do), or if it is off, set it to high quality ?
If the quicktime movie is fine, then the DVD conversion process is the issue. In this case, what did you use to create and burn the DVD ?Read my blog here.
Sony Vegas - Scripting - Adding track motion preset
By samsam in forum EditingReplies: 1Last Post: 7th Oct 2020, 00:52 -
Adding controls to a swf (then adding to website)
By AshleyQuick in forum Newbie / General discussionsReplies: 6Last Post: 14th Oct 2011, 03:02 -
Adding still images to videos [YouTube thumbnails]
By Internet in forum Newbie / General discussionsReplies: 11Last Post: 19th Nov 2009, 01:02 -
HD images
By toneystone in forum Newbie / General discussionsReplies: 3Last Post: 21st Oct 2008, 11:50 -
Divx Bitrate Adjustment - Low Motion or High Motion? TmpgEnc Xpress 4
By Sliztzan in forum Video ConversionReplies: 5Last Post: 31st Aug 2008, 20:11
