I downloaded both files. The MTS file has been reencoded by Youtube to 14fps, but it's ~2x as long. In other words, the two videos have same number of frames. However, Youtube encoded both to around the same bitrate (2250 for Premiere vs 1900 for MTS). If the MTS video were sped up to match the Premiere video, this would double the bitrate of the MTS. This alone explains the difference in frame quality between the two.Originally Posted by Priapism
Premiere video
MTS video
Premiere video
MTS video
Look at the grass and white hairs in all the shots. It's clear that the MTS version retains somewhat more detail. But as I said earlier, it's not a fair comparison since Youtube messed up the conversion.
I think if you upload a video with a decent bitrate (e.g. 6-8Mbps), that's all you need for Youtube. Youtube smushes it down to 2Mbps, so all the detail is lost anyway.
Results 61 to 71 of 71
none of the h264 presets you used are the one i did. check the screenshot of the preset i used and try it - just change the framerate to 29.97fps.Originally Posted by Priapism
to play the video files use media player classic - mpc . light on resources and very good.--
Why on earth would YouTube take a higher quality file (MTS) and re-encode it to 14 frames per second, which is also lower than the lower quality file (Premiere) started with? Now im really confused.Originally Posted by creamyhorror
I guess it couldn't handle the input file. Isn't that what some people have observed when they tried uploading raw footage - Youtube choked on it?Originally Posted by Priapism
See my previous post, which I've updated with screenshots and an explanation for the difference.. -
phew.
my head hurts.
Those clips you show above are kind of blurry all over. There weren't any clear shots to compare?
Thank you for the effort though - i really do appreciate it. -
Hey Cream -
Check out this HD video shot with my same camera.
Pop it onto HD and then pop it into full screen and leg it go for awhile.
Do you think its equivilent in quality to my clips?
Or better? I dont trust my eyes anymore!
http://www.youtube.com/watch?v=L2e3JRbFz54
-P- -
have you checked for updates lately? the current version is 4.1.0
Both are pretty bad quality so most shots are blurry. I compare by zooming in 2x and flipping back and forth between images, and it's quite clear from there.Originally Posted by Priapism
I'm looking at that HD vid now. Looks good, definitely better than the ones you uploaded. I'm trying to download it to check out the internals now.
edit: The download is crawling along, but from what I can tell, the scenes are mostly still shots with a few short, steady pans. Every second of still shot saves a lot of bitrate, which can be spent on making whatever movement there is look good. Once you go handheld shaky footage, all bets are off.
You can try it - put your HF-S10 on a steady surface and film a nice flower up close. Export it via Premiere. I bet when you upload it to Youtube, it'll look all nice and high-def. -
Yeah, I watched the HD video. Bitrate is ~1950Mbps, fps 25. It's full of still shots, especially at the end. These save enough bitrate for the motion scenes to look good. Even then, you can see that it looks smoothed overall, rather than detailed.
As I said, you can achieve the same effect if you use a tripod and film scenes without too much movement. Your export method doesn't won't make as much of a difference as using a tripod/steadicam will.
Adobe Premiere - MainConcept's H.264 vs x264 open source encoder
By rallymax in forum EditingReplies: 159Last Post: 19th Jun 2012, 20:51 -
Adobe Premiere Pro CS5.5 CUDA encoding slow??
By Brainiac in forum EditingReplies: 5Last Post: 23rd Oct 2011, 00:35 -
How to edit .WTV files from Hauppauge HD-PVR (H.264/AC3) in Adobe Premiere
By milOtis in forum User guidesReplies: 2Last Post: 12th Apr 2010, 05:04 -
Adobe Premiere CS4 + GPU H.264 Encoding
By deadrats in forum ComputerReplies: 1Last Post: 11th Dec 2008, 19:01 -
Encoding for uploading YouTube. Best settings with Adobe Premiere Pro 1.5?
By vid83 in forum Video Streaming DownloadingReplies: 2Last Post: 5th Dec 2008, 20:27
