    Aug 2009
    Israel
    hello!!
    I bought a bd370. but everytime I use a disc with MKV or divx (movie) which I burn as a data. it stuck in the begining of the movie- sometimes after 3 minutes, 4 or 5 or right at the begining - I have to forward the disc after the place it stuck and then I can watch the movie until a little bit before it ends - because also at the end it stuck. I used - for example the divx on another LG dvd and it worked propaly. how can this problem be fixed? is it a virus? it happens only with MKV or divx files. thanx in advance
    MOS
    You are in breach of the forum rules and are being issued with a formal warning. One post per topic is enough.
    / Moderator redwudz
  2. Dude, why the need to post the same thread in so many forums? Once is all that is needed.
    Believing yourself to be secure only takes one cracker to dispel your belief.
  3. Banned
    Jun 2004
    ®Inside My Avatar™© U.S.
    WOW!!!
    5 of the same post's!!!!!!
    Better hope someone finds you before Baldrick or your gonna have a short stay
