i used adobe premire to edit a movie and after exporting the movie it seems that the software didn't export the whole file but most of it.
it seems that the file missing the data on the end of the file
i can't open the file with any program that i used.
Is there a way that i can open an unfinished file ? or a least restore some of the data from this file ?
Thanks, Hagai
Results 1 to 1 of 1
What is the best way to join AVCHD and fix for Vegas Movie Studio?
By drguitar in forum Newbie / General discussionsReplies: 6Last Post: 15th Dec 2010, 13:39 -
The timing between movie and subtitle is bad. can I fix that?
By Codonauta in forum SubtitleReplies: 4Last Post: 28th Dec 2009, 13:39 -
Captured VHS movie and .srt subtitle not sync'd. Any way to fix?
By snafubaby in forum SubtitleReplies: 2Last Post: 17th Aug 2009, 01:52 -
Can I fix an .avi movie to get proper dimentions?
By HartsVideo in forum Newbie / General discussionsReplies: 61Last Post: 20th Dec 2008, 09:38 -
How to fix audio sync mid movie?
By 007craft in forum AudioReplies: 3Last Post: 8th Mar 2008, 11:55
