Most NLE software I know of downmixes 5 channel sound to 2 channel. They may "support" 5 channels, but only ones that are created artificially in the editor itself. If the videocam records 5 channels, and various Sony and Panasonic models do, one is out of luck.
Are their any video editing products that keep the 5 channels intact and allow one to export files or burn discs with the same native 5 channel sound?
	VideoReDo and MPEGVCR don't change Dolby 5.1 audio during editing, but based on your question I have the feeling that you may need more functionality than those provide. MPEGVCR is at http://www.womble.com and they have some products that can author DVDs and such in addition to editing. Both products I named are editors ONLY.
	You usually have to adjust the project properties/settings to not downmix by default
 e.g. in vegas you would change the master bus mode in the audio project properties to 5.1 instead of the default stereo. In Premiere Pro, you would change the sequence settings master audio to 5.1 (instead of default stereo). Another approach would be to import as mono wavs
 Which NLE are you using?
  multiAVCHD with intermittent sound in Dolby TrueHDBy wisitch in forum Authoring (Blu-ray)Replies: 1Last Post: 14th Jun 2012, 10:42
  Video Editing Software: mkv, h264 & DTS Editing?By techdls in forum EditingReplies: 8Last Post: 28th May 2011, 02:29
  Importing files with AC3 sound into editing softwareBy jeanpave in forum Video ConversionReplies: 10Last Post: 21st Apr 2010, 02:55
  Good sound editing software for Mac (Tiger)By Crossdive in forum AudioReplies: 2Last Post: 23rd Feb 2010, 13:20
  Software Authoring with support dolby 5.1By arturjose in forum Authoring (DVD)Replies: 2Last Post: 19th Nov 2007, 06:59
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
