Is there a loss of quality if I use the SUPER-program to convert a MP4-file (853 kb) to an output mpeg-2-file (4,87 mb) or an output avi-file (2,68 mb)?
If you say so. But why are the output files bigger than the input file?
Because of higher bitrate. But it doesn't mean that that the quality will be any better or same but you if you use high enough bitrate you shouldn't notice any big difference. And what bitrate you should use depends on the codec like mpeg2 requires higher bitrate than for example mpeg4/divx/xvid.
And you can try mp4cam2avi and it will try remux a mp4 to an avi without any video conversion.
Converting mp4 to avi
By socrates in forum Video ConversionReplies: 2Last Post: 2nd Dec 2010, 08:10 -
Shadow box after converting to Mpeg2/MP4/FLV
By LouieLand in forum Video ConversionReplies: 6Last Post: 1st Feb 2010, 13:11 -
VIDEO_TS folder to MP4/AVI/MPEG2
By jwfc in forum Newbie / General discussionsReplies: 1Last Post: 25th Feb 2009, 02:26 -
converting .mp4 to avi
By georgeyboy in forum Video ConversionReplies: 3Last Post: 6th Nov 2007, 20:13 -
converting mp4 to avi
By georgeyboy in forum Video ConversionReplies: 0Last Post: 6th Nov 2007, 08:03
