Hi,
I have the DVD The Haunted Mansion (2003).
I love the Deleted Scenes from the DVD also!
I have looked more then once to find a DVD unedited with the deleted scenes, however, am unable to find one even for Blue-Ray!
How do I edit my DVD to where the deleted scenes are placed in the correct spot of the movie, whether it be avi or some other format and if there is a easy way that would be greatly appreciated also? Please and thank you!
Thanks so much! Have a great one! God bless!
manquala@yahoo.com
Demux the main movie and the deleted scenes using VOB2MPG, then use an MPG editor (VideoRedo, Womble Mpeg Video Wizard, Tmpgenc Mpeg Editor) to cut the deleted scenes back into the main feature. Output a new mpeg file, and author a new DVD. You should be able to do this with not quality video loss. Audio may be a different matter, as the main feature most likely has 5.1 surround, but the deleted scenes usually only have 2.0. You will either have to mix down the main to 2.0, or make a fake 5.1 for your deleted scenes ebfore you edit.
Read my blog here.
Thanks so much!
How do I put the deleted scenes exactly where they belong in the movie does software help put it in the correct spot also? Please and thank you! -
You will have to find the correct locations yourself. It is a manual process only. That said, it should not be difficult to find the points where the clips need to go and to put them back in. I would estimate no more than an hour to do most of the work. Usually deleyed scenes on a DVD have some of the existing scene at the start to provide context, so you will have some overlap to play with.Originally Posted by GhtpuaRead my blog here.
Converting DVD Deleted Scenes to MP4 - Subtitles Don't Match
By rickydavao in forum DVD RippingReplies: 1Last Post: 14th Mar 2012, 02:46 -
How to Add Deleted Scenes & make it complete version?
By skorpinok in forum Video ConversionReplies: 2Last Post: 1st Jan 2012, 07:29 -
Need to put a bunch of movie scenes together
By neworldman in forum EditingReplies: 2Last Post: 1st Oct 2011, 22:55 -
Gui dvd author-jumping movie in fast motion scenes due to high video bitrat
By extent in forum Authoring (DVD)Replies: 8Last Post: 19th Feb 2009, 08:30 -
Remaking Special Edition: Inserting Deleted Scenes
By snipper_cr in forum EditingReplies: 0Last Post: 16th Dec 2007, 14:45
