ok. i have pal dvd that i ripped to mkv. Is it possible to then use convertxtodvd to burn it to dvd and have it be viewable on a ntsc set. I regularly convert and burn mkv's to dvd and they are watchable. basically, is it possible to essentially convert pal to ntsc this way?
Thank you![]()
Yes, it is possible to convert a DVD this way. It is not a method I would recommend, nor one that will produce the best outcome, however it is a fast method, and if you are happy to do it this way, go ahead.
Personally, I would get a player that happily plays both formats, so this would not be an issue (actually, as I come from Australia, this is not an issue as most kit plays everything here). At the very least I would skip the mkv step as unnecessary, as any extra re-encoding reduces quality.Read my blog here.
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 11:19 -
How to play MKV, MKV to AVI, MKV to DVD, MKV to Xbox 360 or Playstation 3
By Baldrick in forum Video ConversionReplies: 2Last Post: 8th Mar 2012, 02:45 -
mkv question... many mkv files (with subs) into 1 mkv?
By 0okami in forum EditingReplies: 1Last Post: 24th Oct 2009, 00:45 -
MKV Question
By gcrutcher in forum Newbie / General discussionsReplies: 3Last Post: 24th Mar 2009, 18:52 -
I have a question about MKV
By sdavis in forum Blu-ray RippingReplies: 12Last Post: 23rd Mar 2009, 06:02
