Which of the free software tools recommended here meets or gets closest to the following criteria. Or recommend a paid software.
Lightweight (small footprint)
portable (no install required)
can use multiple cores for faster conversion
thanks
Results 1 to 21 of 21
What are your source files and what do you want for output files?
i.e. convert from "blank" to "blank"
Need more info!Donadagohvi (Cherokee for "Until we meet again") -
sorry, I was referring to video converters for most formats. Usually I convert things to avi. For example mp4 to avi.
Try Free Zune Video Converter.Lightweight (small footprint)
portable (no install required) -
tried it, I don't think ffmpeg does mp4 to avi. It said "Unsupported codec for output stream #0.0"Originally Posted by Baldrick
Yes, it's a good encoder also as you can use x264,xvid,etc...but you probably need to adjust a lot of parameters to get the best quality.Originally Posted by usta
sdvideo: what ffmpeg version? where did you download it? different versions support different video and audio codecs. But it doesn't support everything though...but almost. -
I tried it under winff now and still same problem.
Seems stream 0 codec frame rate differs from container frame rate: 47.95 (200000
00/417083) -> 23.98 (24000/1001)
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'G:\vids\Interview with the Vampire.mp4'
Duration: 02:02:33.38, start: 0.000000, bitrate: 1637 kb/s
Stream #0.0(und): Video: h264, yuv420p, 1280x720 [PAR 1:1 DAR 16:9], 23.98 t
br, 23.98 tbn, 47.95 tbc
Stream #0.1(und): Audio: aac, 48000 Hz, 5.1, s16
Output #0, avi, to 'G:\dl\Interview with the Vampire.avi':
Stream #0.0(und): Video: msmpeg4, yuv420p, 640x480 [PAR 4:3 DAR 16:9], q=2-3
1, 1000 kb/s, 90k tbn, 23.98 tbc
Stream #0.1(und): Audio: libmp3lame, 44100 Hz, 5.1, s16, 192 kb/s
Stream mapping:
Stream #0.0 -> #0.0
Stream #0.1 -> #0.1
Error while opening codec for output stream #0.1 - maybe incorrect parameters su
ch as bit_rate, rate, width or height -
how do i change the settings? I am using the standard xbox preset.
I don't think the AVI container supports 5.1 audio?Originally Posted by sdvideo
I've tried it with aac and ac3 and get corrupted playback.
If so, you'll have to down-mix the audio to two channels or use another container that xbox supports. -
Yeah, I realized it later...
But it all depends on how much experience one has with video conversion. A beginner may find Free Zune Video Converter just perfect. A more experienced user may go deep into the settings..
For XBOX you can use MP4 as a container with AAC as audio codec.how do i change the settings? I am using the standard xbox preset.
In WinFF, I would add to the audio preset command line this (audio channel 2):
-ac 2 -
using -ac 2, I get:
you suggested I use mp4 for xbox? IS mp4 different than mpeg4?Resampling with input channels greater than 2 unsupported.
Can not resample 6 channels @ 48000 Hz to 2 channels @ 48000 Hz -
.mp4 is a container format and a subset of MPEG-4 (MPEG-4 part 14)
MPEG-4 encompasses about 20 different things
http://en.wikipedia.org/wiki/MPEG-4 -
Well, "-ac 2" command specifies the number of output channels (stereo in this case).
I'm also just learning ffmpeg, so perhaps, someone experienced can suggest an elegant approach to handle 5.1 audio input into 2 channel audio conversion?
For now, I'd try to add this command: "-map 0:2", where 2 would the audio stream number of the input file. -
i've tried several decoders and several presets and it still doesn't work. I have no idea what is left to try.
ask for some complete free software
By ieh4f in forum DVD RippingReplies: 1Last Post: 15th Apr 2011, 09:51 -
Heads up: Free Conversion software
By oldfart13 in forum Latest Video NewsReplies: 2Last Post: 17th Jan 2011, 15:58 -
What are the best free editing software?
By OM2 in forum EditingReplies: 7Last Post: 11th Apr 2010, 18:38 -
Free Software Tool?
By donkeyking in forum Newbie / General discussionsReplies: 2Last Post: 17th Nov 2008, 19:02 -
free conversion software????
By dj10fld in forum Video ConversionReplies: 1Last Post: 12th Sep 2008, 12:18
