Greetings;
I have a set of video files that have the extension ".h264", the files are from a CCTV surveillance system that we have at our work. The CCTV system included some sort of video player called "HEMPlayer" which seems to be made by "Hyper Electronics".
Now, I've searched everywhere for that HEMPLAYER but I can't find it, and such Hyper Electronics company doesn't exists.
I was reading in the forums about using alltoavi / Winavi to decode the videos but both programs crash when I try to convert any of the .h264 files.
It is very important for me to decode this videos because it contains valuable data that needs to be used by the local authorities.
I hope that anyone can help me in this matter. If there is something else that I need to do please let me know, I'm running against the clock.
Thanks in advance![]()
Fred
Can you open it in DGAVCIndex ?
If it's just a raw elementary stream, just put it into a container e.g. yamb for .mp4 , or mkvtoolnix for .mkv , or tsmuxer for .ts, then most media players should be able to play it e.g. vlc, kmplayer etc...
If it's a proprietary codec or format you might be out of luck
What is your goal? Just to watch it? or convert it? -
It may be a proprietary format variation which will force you back to "Hyper Electronics" for support.
http://www.kiva.org/about -
First of all thanks for the fast reply.
Our goal is to convert the video to any type of media that is commonly used (Avi Mpg or so) so that the authorities can use the video as evidence. If we don't convert it, then there is no way we will be able to give the evidence to the authorities (We have the video of a robbery)
As edDV said
The problem with that is that there is no such Hyper Electronics around here, not even on the internet. We talked to the company that provided the CCTV system and they said the "hemplayer" has a "convert to avi" option but it doesn't works. It just makes a 0KB .avi file.It may be a proprietary format variation which will force you back to "Hyper Electronics" for support.
I will try poison's suggestions and will come back with the results.
Once again thank you so much for the help. -
The DGAVindex came out with errors.
thenFound NALU Type 0, len 31 undefined, ignored NALU, moving on
Concealing (lots of numbers here) DC, (more numbers) AC, MV errors
Not good.
Problems converting some xvid to h264 to append to another h264
By PlanetIndigo in forum Video ConversionReplies: 3Last Post: 6th Jun 2011, 14:13 -
H264 Playback Problems in WMP 11
By seasonsofwither in forum Software PlayingReplies: 3Last Post: 21st Dec 2009, 22:49 -
MKV/H264 problems
By Alexstarfire in forum Video ConversionReplies: 10Last Post: 5th Oct 2009, 17:17 -
CCTV Advise
By Squid_uk in forum Off topicReplies: 2Last Post: 6th Jun 2008, 16:55 -
Sound problems with h264 (iPod conversion)
By hackwojr in forum ffmpegX general discussionReplies: 17Last Post: 15th Jul 2007, 20:45
