Hi, all!
What can be done to get rid of this kind of VHS tape artifact?
I know of no other solution than to hand edit that frame. Hopefully, you can cut and paste from previous frames.
Darryl -
I've got a 1-hour footage spoiled with such noise. A group of 20-30 half-dropped lines appears in the same place in each frame throughout the whole clip. May be there is some specific filter that could be applied locally (I mean for a particular group of lines in a frame)
Thanks for reply -
NeatVideo. Best results I've seen. However, it's indeed extremely slow.
In all honesty that looks like a very bad case of tape damage/degradation. You might be out of luck in trying to truly remove it, but I never say never. Try the filter listed in the post above or as another suggested to fix it via photoshop as frames (which would take months) if possible
That problem is that the tape has a crease near the edge thats cause by a faulty/dirty pinch roller and cant be fixed by any method,only thing that can be done is to merge the pixels above and below into the middle with filters which wont help much anyways.
You can open the flap on the vhs tape and see the crease.I think,therefore i am a hamster. -
Ironing of the tape --- MAYBE!
vhs tape will NOT move through vhs recorder at all
By tepeco in forum RestorationReplies: 52Last Post: 24th Oct 2022, 12:31 -
Sharp VCR (or similar) S-VHS quality for best capture of my VHS tape?
By ruehl84 in forum Capturing and VCRReplies: 0Last Post: 19th Feb 2012, 15:52 -
How can VHS tape color loss be possible? ("tape fade")
By lordsmurf in forum RestorationReplies: 31Last Post: 18th Oct 2010, 09:32 -
vhs ntsc tape
By erlingre in forum LinuxReplies: 2Last Post: 17th Oct 2007, 16:52 -
Archiving VHS Tape
By mts37 in forum Newbie / General discussionsReplies: 3Last Post: 8th Jun 2007, 01:17
