I downloaded a .asf of black keys stream and I can't watch it in anything currently.
I could watch it with wm9 a long time ago now it won't play.
Is there anything I can do?
thanks
Code:FileName : BlackKeys.asf Data : 30 26 B2 75 8E 66 CF 11 A6 D9 00 AA 00 62 CE 6C 0& u f b l A8 20 00 00 00 00 00 00 0B 00 00 00 01 02 A1 DC AB 8C 47 A9 CF 11 8E E4 00 C0 0C 20 53 65 68 00 G Seh 00 00 00 00 00 00 41 DB 28 00 ED 1A FA 47 89 B3 A ( G DB 2B 9B BE 13 02 DA F6 0E 13 00 00 00 00 10 19 + BE 12 32 B0 C7 01 79 B0 01 00 00 00 00 00 90 8B 2 y EF 3E 06 00 00 00 10 9B F4 3B 06 00 00 00 88 13 > ; 00 00 00 00 00 00 02 00 00 00 48 0B 00 00 48 0B H H 00 00 C1 F3 00 00 FB B3 11 22 23 BD D2 11 B4 B7 "# 00 A0 C9 55 FC 6E 91 00 00 00 00 00 00 00 18 00 U n 00 00 6A 22 25 17 E2 0D 2F 2D 39 3A ED 3A FA 61 j"% /-9: : a F8 38 67 82 61 7A D1 8B D8 C6 04 00 00 00 44 52 8g az DR 4D 00 19 00 00 00 61 69 37 72 67 45 34 43 59 78 M ai7rgE4CYx 6D 4F 4E 34 47 7A 32 34 41 6E 67 67 3D 3D 00 34 mON4Gz24Angg== 4 00 00 00 68 74 74 70 73 3A 2F 2F 62 6C 75 65 72 https://bluer 6F 6F 6D 2E 69 73 74 72 65 61 6D 70 6C 61 6E 65 oom.istreamplane 74 2E 63 6F 6D 2F 64 72 6D 2F 62 6C 75 65 72 6F t.com/drm/bluero 6F 6D 2E 61 73 70 00 14 E6 8A 29 22 26 17 4C B9 om.asp )"&L 35 DA E0 7E E9 28 9C 4E 03 00 00 00 00 00 00 32 5 ~ ( N 2 03 00 00 3C 00 57 00 52 00 4D 00 48 00 45 00 41 < W R M H E A 00 44 00 45 00 52 00 20 00 76 00 65 00 72 00 73 D E R v e r s 00 69 00 6F 00 6E 00 3D 00 22 00 32 00 2E 00 30 i o n = " 2 . 0 00 2E 00 30 00 2E 00 30 00 22 00 3E 00 3C 00 44 . 0 . 0 " > < D 00 41 00 54 00 41 00 3E 00 3C 00 43 00 48 00 45 A T A > < C H E 00 43 00 4B 00 53 00 55 00 4D 00 3E 00 6A 00 38 C K S U M > j 8 00 34 00 72 00 2B 00 34 00 46 00 54 00 37 00 77 4 r + 4 F T 7 w 00 3D 00 3D 00 3C 00 2F 00 43 00 48 00 45 00 43 = = < / C H E C 00 4B 00 53 00 55 00 4D 00 3E 00 3C 00 4B 00 49 K S U M > < K I 00 44 00 3E 00 61 00 69 00 37 00 72 00 67 00 45 D > a i 7 r g E 00 34 00 43 00 59 00 78 00 6D 00 4F 00 4E 00 34 4 C Y x m O N 4 00 47 00 7A 00 32 00 34 00 41 00 6E 00 67 00 67 G z 2 4 A n g g 00 3D 00 3D 00 3C 00 2F 00 4B 00 49 00 44 00 3E = = < / K I D > 00 3C 00 4C 00 41 00 49 00 4E 00 46 00 4F 00 3E < L A I N F O > 00 68 00 74 00 74 00 70 00 73 00 3A 00 2F 00 2F h t t p s : / / 00 62 00 6C 00 75 00 65 00 72 00 6F 00 6F 00 6D b l u e r o o m 00 2E 00 69 00 73 00 74 00 72 00 65 00 61 00 6D . i s t r e a m 00 70 00 6C 00 61 00 6E 00 65 00 74 00 2E 00 63 p l a n e t . c 00 6F 00 6D 00 2F 00 64 00 72 00 6D 00 2F 00 62 o m / d r m / b 00 6C 00 75 00 65 00 72 00 6F 00 6F 00 6D 00 2E l u e r o o m . 00 61 00 73 00 70 00 3C 00 2F 00 4C 00 41 00 49 a s p < / L A I 00 4E 00 46 00 4F 00 3E 00 3C 00 53 00 45 00 43 N F O > < S E C 00 55 00 52 00 49 00 54 00 59 00 56 00 45 00 52 U R I T Y V E R 00 53 00 49 00 4F 00 4E 00 3E 00 32 00 2E 00 32 S I O N > 2 . 2 00 3C 00 2F 00 53 00 45 00 43 00 55 00 52 00 49 < / S E C U R I 00 54 00 59 00 56 00 45 00 52 00 53 00 49 00 4F T Y V E R S I O 00 4E 00 3E 00 3C 00 2F 00 44 00 41 00 54 00 41 N > < / D A T A 00 3E 00 3C 00 53 00 49 00 47 00 4E 00 41 00 54 > < S I G N A T 00 55 00 52 00 45 00 3E 00 3C 00 48 00 41 00 53 U R E > < H A S 00 48 00 41 00 4C 00 47 00 4F 00 52 00 49 00 54 H A L G O R I T 00 48 00 4D 00 20 00 74 00 79 00 70 00 65 00 3D H M t y p e = 00 22 00 53 00 48 00 41 00 22 00 3E 00 3C 00 2F " S H A " > < / 00 48 00 41 00 53 00 48 00 41 00 4C 00 47 00 4F H A S H A L G O 00 52 00 49 00 54 00 48 00 4D 00 3E 00 3C 00 53 R I T H M > < S 00 49 00 47 00 4E 00 41 00 4C 00 47 00 4F 00 52 I G N A L G O R 00 49 00 54 00 48 00 4D 00 20 00 74 00 79 00 70 I T H M t y p 00 65 00 3D 00 22 00 4D 00 53 00 44 00 52 00 4D e = " M S D R M 00 22 00 3E 00 3C 00 2F 00 53 00 49 00 47 00 4E " > < / S I G N 00 41 00 4C 00 47 00 4F 00 52 00 49 00 54 00 48 A L G O R I T H 00 4D 00 3E 00 3C 00 56 00 41 00 4C 00 55 00 45 M > < V A L U E 00 3E 00 42 00 49 00 6D 00 4E 00 59 00 5A 00 31 > B I m N Y Z 1 00 31 00 54 00 32 00 52 00 66 00 4A 00 4B 00 34 1 T 2 R f J K 4 00 69 00 38 00 78 00 34 00 4D 00 2F 00 37 00 74 i 8 x 4 M / 7 t 00 77 00 54 00 51 00 49 00 74 00 48 00 52 00 6B w T Q I t H R k 00 6E 00 4D 00 4F 00 4B 00 33 00 45 00 4D 00 70 n M O K 3 E M p -------------------- [File Info] -------------------- L:\BlackKeys.asf General Complete name : L:\BlackKeys.asf Format : Windows Media File size : 305 MiB Duration : 44mn 37s Overall bit rate mode : Constant Overall bit rate : 955 Kbps Maximum Overall bit rate : 62.4 Kbps Encoded date : UTC 2007-06-16 16:19:11.265 Encryption : https://blueroom.istreamplanet.com/drm/blueroom.asp Video #8 Format : VC-1 Format profile : MP@LL Codec ID : WMV3 Codec ID/Info : Windows Media Video 9 Codec ID/Hint : WMV3 Duration : 44mn 37s Bit rate mode : Constant Bit rate : 29.0 Kbps Width : 178 pixels Height : 100 pixels Display aspect ratio : 16/9 Frame rate : 15.000 fps Resolution : 24 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.108 Language : en-us Encryption : Encrypted Audio #4 Format : WMA2 Format profile : L2 Codec ID : 161 Codec ID/Info : Windows Media Audio 2 Duration : 44mn 37s Bit rate mode : Constant Bit rate : 12.0 Kbps Channel(s) : 2 channels Sampling rate : 8 000 Hz Resolution : 16 bits Language : en-us Encryption : Encrypted
Results 1 to 1 of 1
remove drm ?
By BoruII in forum MacReplies: 6Last Post: 23rd Jan 2011, 20:20 -
Cannot play ASF (WMV) files in Windows Media Player
By javaluvva in forum Software PlayingReplies: 3Last Post: 15th Jul 2010, 21:57 -
WMP11 can't play .asf?
By ChiSholm in forum Software PlayingReplies: 2Last Post: 8th Jan 2009, 07:19 -
M$ DRM cracked - again
By Conquest10 in forum Latest Video NewsReplies: 4Last Post: 8th Aug 2007, 12:50 -
DRM snafu!
By marknyc5 in forum AudioReplies: 11Last Post: 3rd Jul 2007, 02:13
