Dear Board:
My question is:
I have recently ripped a copy of King Kong Blu-Ray to my computer. I have all sorts of programs that I normally use to create such a conversion. What I am trying to do is take the ripped video file, that uses the VC-1 codec, and convert it to x264. I have done this same process with another bluray and it worked perfectly. The problem with this particular rip is the original ripped video file plays perfectly. The video is crisp and the colors are as they should be. This is a .mkv format (my original rip, that is). When I take that .mkv and use the MeGUI to create an AVISynth, and encode the file to .264 format (the same way I do all the others), I get a video that is playable; however, the screen looks almost like there are two video layers on top of each other that don't line up properly. There are strange hue's in the video and is unwatchable, much less HD. It looks like there is about a centimeter offset. The offset is apparent if you look at the bottom of the video. The color "problem" shows clearly from the bottom of the video up about 1 centimeter. I am so confused as to why this is happening when the original .MKV input file plays perfectly. I have done this very same rip with another movie and had no issues.
Any help would be much appreciated.
What would cause this?
Thanks,
Matt
Results 1 to 13 of 13
I have tried using Handbrake (which is another program I use often) but it says it cannot find any indexes or chapters, something of the sort.. i cannot remember the exact error right off; however, it is an error, nonetheless.
Any other ideas?
It just baffles me because doing things the same way on other blurays work perfect. Do you think it has something to do with the VC-1 codec? I am not certain that the other blurays used the same codec. Seems like one of the others was a different one. -
UPDATE: Solved.
I experienced the same issue with another movie "Chronicles of Riddick" I got fed up, so I re-installed the FFDSHOW codec/program that RipBotx264 was requesting. When I first loaded the RipBotx264 (recommended above) it said I was missing the FFDSHOW. Once I downloaded it, it completely fixed my issue. Who knows, perhaps a bad Windows 7 codec? I have the recommended Shark codecs for Windows 7, but perhaps that particular one was left out or corrupted.
In any event, problem solved.
Thanks for all the help,
Matt -
What are "Shark codecs"? If you are talking about installing one of those codec packs that promises to play everyone on your PC after you install them, that could be your problem. Codec packs often conflict with each other. The general rule is to install as little as possible and only what you need and to avoid installing those monstrous codec packs available on the internet.Originally Posted by MisterZJ
I searched for the Windows 7 codecs online and found many that recommended the Shark codecs: http://shark007.net/win7codecs.html
I know my issue with the color problem was instantly resolved by simply re-installing or installing the FFDSHOW.
Who knows? I have the RC version of Windows 7 x64, so i'm not sure as to what actually corrected the issue.
Just glad to have it resolved.
Now, if I can just remember what I did come March when my RC version starts shutting down every 2 hours haha!
Just doing a quick read about Shark, it looks like it uninstalled ffdshow, then installed a different version and that may have been the problem. Codec packs are a bad idea, IMO, no matter what their authors might say, and commonly cause more problems than they solve.
and you prove to be right Red
Seems like I originally installed it because I couldn't get mkv's to playback, when the best approach probably would have been download the Matroksa or whatever codec directly
Thanks again!
Can i burn avi/mp4/mkv etc to blu ray media and play it in a blu ray player
By brad350 in forum Newbie / General discussionsReplies: 10Last Post: 21st Apr 2012, 04:15 -
Best way to view a Ripped Blu-ray
By PHNeedsHelp in forum Blu-ray RippingReplies: 5Last Post: 1st Feb 2012, 22:24 -
Ripped blu-ray. Now what?
By whoisquilty in forum MacReplies: 5Last Post: 2nd Aug 2010, 17:36 -
BLU-RAY Ripped
By pensioner in forum Newbie / General discussionsReplies: 7Last Post: 11th Feb 2009, 22:37 -
Burning Blu Ray from ripped Blu Ray
By ppurdue in forum Blu-ray RippingReplies: 10Last Post: 15th Oct 2008, 19:51
