Hi!
There are several programs that extract audio from video files, but I haven't been able to find one that would extract video.
In other words, just to be precise, I want to keep the video and discard the audio.
I am talking of files like .mov, .wmv, .avi, .mpeg, and all the other video formats.
My technical expertise is nil, so if there is a specific program that can do this I'd greatly appreciate your help.
Thanks in advance,
iami
Results 1 to 12 of 12
There are different tools for different types of files. No single tool can process them all, except ffmpeg comes close, it's like a "swiss army knife", but runs with command line.
e.g for GUI type applications you could use
mov => yamb
avi => vdub or avidemux
mpeg => dgindex
transport streams => tsmuxer
mkv => mkvextract -
What you want to do is called De-Muxing, short for De-Multiplexing. Different progs for different formats. They do not so much Extract the video as divide the video and audio into seperate files. A key to this process is that there is no degradation or change to the video in any way.
Thank you, poisondeathray, that helps me with most of my files.
I have, however, many in the .wmv format. Is there anything for that type of file?
And one last question, if I may, I see that the programs you mention are all free. Isn't there a commercial program that would work with any type of file?
Thanks again. Appreciate much your help. -
Thank you, Nelson37. I did a search for the two words that you mention and indeed it seems that there is no easy "generic" way to extract video. I thought it was much easier and more common. Apparently many more people want to extract audio than video. Strange.
There might be, but I don't know of any commerical program that would do it allOriginally Posted by iami
Thank you, El Heggunte. With this and poisondeathray's programs I am pretty much covered. I also have a few (just 2 or 3 each) files in the .divx and .mp4 formats. Any specific programs for those?Originally Posted by El Heggunte
Avidemux should be able to for both, and yamb specifically for .mp4Originally Posted by iami
By the way, you are not really "extracting" with this when using avidemux, you are just re-multiplexing into a new container without the audio (ie. copying the video into a new container, without the audio)
For some of programs listed, you actually get the elementary video stream. Many elementary streams are usually not "playable" by most media players until they are placed into a container like .mp4, .avi, etc... -
Thank you, poisondeathray, it seems that now I am complete.
I have a new question, though, how do I place the new files in a container? Sorry, but my knowledge is really "inexistent"...Originally Posted by poisondeathray
Not all videos are compatible in every container. You should stick with the one it came in. The exception would be .mov which windows doesn't handle very well (it's intended for macs), instead just put it into .mp4. But you can keep .mov with ffmpeg. There are some GUI's for ffmpeg as well, like avanti, that may help if you're not familiar with command line
Often it's just the same program. e.g. in yamb you would open the .mp4, uncheckmark the audio stream, while leaving the video stream checked. Essentially you are copying the file, but without the audio.
I can't go into detail for every single file type, so if you run into specific problems, post a specific question and someone will help you
Cheers -
Thank you all for yesterday's "demuxing crash course"
Now I have the tools I need and some knowledge to start from.
Looks like this is a great forum and am glad to have found it.
Cheers! This one is for you...
How To Extract One Video From Three
By Treeant34 in forum Newbie / General discussionsReplies: 6Last Post: 3rd Apr 2012, 11:48 -
How do you extract only the video with AVIdemux?
By Djard in forum Video ConversionReplies: 2Last Post: 30th Jan 2012, 17:25 -
extract frame from video
By ahidayat in forum Newbie / General discussionsReplies: 7Last Post: 28th Feb 2009, 02:45 -
Extract video from DVD
By prl in forum DVD RippingReplies: 8Last Post: 8th Jan 2009, 15:35 -
Extract video to mp3?
By chronic777 in forum Newbie / General discussionsReplies: 6Last Post: 12th Aug 2008, 15:11
