I use Vegas 9 Platinum and have recently found a problem with increasing playback speed of my video clips.
I recently moved and had my pc shut down for a couple days and when I set everything up and started edited again i discovered the current problem. I've tried using old clips that have been in Vegas before and adding new ones to test out the problem but either way if i try and squeeze (speed up) a clip in vegas the video in that clip goes black. In the timeline i can still see the still frames used for identifing the clip but if i place the cursor anywhere on the clip i get black nothing in the preveiw and the same thing happens if i try playing the clip. But if i try and stretch (slow down) a clip everything works just fine.
I've done hardware/software maintanence, system restore and uninstall/reinstalled the program but the problem still remains. while this isn't a major problem it just plain bugs and confuses me.
Any help would be appreciated. Thanks
Problem solved. Disabled resample under switches in clip options
The reverse problem -- speeding up video (2x) to match audio
By hlygrail in forum Video ConversionReplies: 9Last Post: 2nd Dec 2009, 13:06 -
Creating clips with Vegas
By Abas-Avara in forum EditingReplies: 2Last Post: 10th Oct 2009, 17:57 -
adobe premiere 6.0 problem clip speeding up why?
By suomiaussie in forum EditingReplies: 5Last Post: 20th May 2008, 22:02 -
Speeding up Dell Dimension for AVCHD and Vegas Movie Studio or New Comp
By sierra1049 in forum Newbie / General discussionsReplies: 7Last Post: 3rd Jul 2007, 19:15 -
How can I play 4 clips on SONY VEGAS 7.0?
By qazwsx16 in forum EditingReplies: 2Last Post: 28th May 2007, 19:28
