hello all,
I have a bunch of divx with their srt files in Arabic but everytime i load the srt file in vlc or smplayer it shows
like question marks or strange and unreadable characters, if i load english subtitles it will work just fine but not the arabic ones , i tried this on many different pcs and same story everywhere, please is there a way to fix this ?
thanks for any help
The title of your post is horrible. "question marks or strange and unreadable characters" are NOT "like Chinese" as your title says. In fact, saying "Subtitles showing in strange unreadable characters" would have been accurate. We know what that means.
Anyway, SRT files are text files. The problem is that American computers aren't typically installed to display anything but Latin characters. Open the SRT files with some text editor like Word or Wordpad. Do the characters look OK to you? If not, you'll have to do something like this. Go to Control Panel -> Regional And Language Options -> Advanced and change "Select a language to match the language version of the non-Unicode programs you want to use" to whatever version of Arabic (there are a lot of them) is appropriate. You may have to reboot. Note that this will change the display of some of your programs to Arabic or mess them up completely. There are potential negative consequences of doing this, but it may be the only way to get the subtitles to work. If you have a way to install Arabic fonts on your PC, that may possibly fix the problem without doing what I suggested. Also if you can figure out a way to change the SRT files from whatever character set they are in to Unicode and save that, that may allow VLC and smplayer to work OK. Note that Unicode subs have many drawbacks as most standalone DVD players can't play them and most subtitle programs can't use them as input.
Chinese subtitles require Chinese font on the computer?
By Haopengyou in forum SubtitleReplies: 0Last Post: 24th Mar 2012, 12:04 -
Chinese & Serbo-Croatian subtitles corrupted in DVDLab Pro
By umforrest in forum Authoring (DVD)Replies: 3Last Post: 27th Aug 2011, 14:17 -
How to I convert Chinese srt to HD subtitles?
By TetsuSama69 in forum SubtitleReplies: 4Last Post: 31st Dec 2010, 18:58 -
Converting traditional Chinese subtitles to simplified
By Haopengyou in forum AudioReplies: 1Last Post: 20th Jun 2010, 11:40 -
Adding chinese subtitles to original DVDs
By viewpoint in forum SubtitleReplies: 4Last Post: 17th Aug 2009, 12:08
