Hello,
I'm new in this forum and also in mkv topic and I need help with reencoding mkv to be playable on my player. I have a mkv file which has 16 ref-frames and I need to decrease it somehow to 3-5. I have to mention that original mkv file has no audio/video sync problem. I found Handbrake tool and try it but after conversion I got audio out of sync. Then I found MKVextract and MKVmerge tools so I tried to extract everything from original mkv file, convert only video file (only change I made there was decreasing of ref-frames) and then I merge reencoded video file with previously extracted audio file. But I got the same audio out of sync problem. I also tried Xvid4PSP but I got same audio problem.
Does anybody know where the problem could be or what I'm doing wrong?
Thanks for any answer.
Closed Thread
Try uncropmkv,i find it better for re-encoding mkv and keeping the audio in synch and welcome to the forum.
What kind of sync problem? Progressive where it get worse and worse or same sync in the while video?
I would guess it's a mkv with variable framerate. Can you post the mediainfo details from the mkv ?
Here is the detailed information about original mkv file where I need to reduce ref-frames count to 3-5. without destroying audio sync (any help appreciate) :
General
Complete name : M:\Movie\_HD\Planet.Earth.1.FULL.HD.x264\Planet.Ea rth.1-Z.polu.na.pol.FULL.HD.x264.5.1EN.2.0CZ_.mkv
Format : Matroska
File size : 4.36 GiB
Duration : 51mn 10s
Overall bit rate : 12.2 Mbps
Encoded date : UTC 2009-08-16 09:40:07
Writing application : mkvmerge v2.9.8 ('C'est le bon') built on Aug 13 2009 12:49:06
Writing library : libebml v0.7.7 + libmatroska v0.8.1
Cover : Yes / Yes
Video
Format : AVC
Format profile : High@L5.1
Format settings, CABAC : Yes
Format settings, ReFrames : 16 frames
Muxing mode : Container profile=Unknown@5.1
Codec ID : V_MPEG4/ISO/AVC
Duration : 51mn 6s
Bit rate : 11.2 Mbps
Nominal bit rate : 11.3 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 fps
Resolution : 24 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.226
Stream size : 4.01 GiB (92%)
Writing library : x264 core 55 svn-655
Encoding settings : cabac=1 / ref=16 / deblock=1:-2:-1 / analyse=0x3:0x133 / me=umh / subme=7 / brdo=1 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=0 / threads=2 / nr=0 / decimate=0 / mbaff=0 / bframes=3 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=3 / wpredb=1 / bime=1 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=2pass / bitrate=11305 / ratetol=1.5 / rceq='blurCplx^(1-qComp)' / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30
Audio #1
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 2
Codec ID : A_MPEG/L2
Codec ID/Hint : MP2
Duration : 51mn 10s
Bit rate mode : Constant
Bit rate : 256 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Resolution : 16 bits
Stream size : 93.7 MiB (2%)
Title : Czech (Stereo)
Language : Czech
Audio #2
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : A_AC3
Duration : 51mn 10s
Bit rate : 448 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Surround: L R, LFE
Stream size : 164 MiB (4%)
Title : English (AC3)
Language : English
Text #1
Format : ASS
Codec ID : S_TEXT/ASS
Codec ID/Info : Advanced Sub Station Alpha
Language : English
Text #2
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Language : Czech
Change avc level and reference frame
By cote112 in forum Video ConversionReplies: 2Last Post: 24th Mar 2011, 10:45 -
MKV with Variable Framerate convert to MP4 problem
By beaniekapp in forum Video ConversionReplies: 12Last Post: 4th Jul 2010, 08:44 -
Change IDX/SUB Framerate
By r9800pro in forum SubtitleReplies: 8Last Post: 15th May 2010, 22:46 -
Change MP4 framerate
By exon in forum Video ConversionReplies: 3Last Post: 22nd Mar 2010, 08:00 -
How to change framerate in XviD4PSP other than 15.000 ???
By d003232 in forum Video ConversionReplies: 0Last Post: 26th Apr 2009, 13:24
