Hey guys,
I'm using BeSure/BeSweet to try to transcode an AC3 file to 6 separate WAV files to burn a DTS CD. All channels come out fine except the Right Surround channel, which comes out blank, every time. Any thoughts on what could be causing this? I tried a couple different rippers to create the AC3 file, with different settings, but to no avail. Any help would be greatly appreciated, thank you!!
Results 1 to 9 of 9
Does it have to be a DTS CD ? An AC3 CD cannot be an option
Because recompressing AC3 into DTS is a lossy process.
Anyway, eac3to would be a bettter choice than HeadAC3he or the "Be-Something" apps.
If your AC3 source already is @ 44.1kHz,
you can simply convert it to a CD-ready .WAV with spdifer.exe
(included in the AC3Filter Tools package).
HTH. -
Well, I was following a guide for making a DTS-CD. According to the guide you must use BeSure/BeSweet to convert an AC3 file to 6-mono WAV files, each WAV file representing a DTS channel. Then SurCode takes those six mono-WAV files and makes one DTS WAV file, which you can burn like any normal, and listen to it through a home theater system with DTS capability. Unfortunately, I get every separate channel but the Right Surround, for some reason. Otherwise, everything works. I can burn the DTS WAV to a CD and I get sound out of every channel except the Right Surround.
Would an AC3-CD give you stereo sound, or surround sound? Making a DTS-CD seemed like an easy process, so I thought I'd try it. And except for this little snag it WAS pretty easy.
I'll have to look into trying eac3to. -
Also, do you guys know of any other successful and non-lossy methods of making a DTS-CD? It didn't really sit right with me that converting from CD -> AC3 -> WAV was a lossy process, but I don't know any other methods.
And thanks to both of you for the help and software suggestions so far
I'm pulling my hair out here because I seem to be doing everything right but it's just not working.
Which is exactly what you asked for.Originally Posted by SliceOfHorse
However, since you addded
this is clearer. That's a pretty silly way, I don't do DTS, but on general principle, you don't go through a lossy encoding if you can avoid it.Originally Posted by SliceOfHorse
Maybe asking at a hifi audio forum like http://www.hydrogenaudio.org/forums might be more fruitful. -
One quick question the original CD you used has how many channels?Originally Posted by SliceOfHorse
decode 5.1 matrix surround wav file to 6 mono wav files
By Zerrax in forum AudioReplies: 2Last Post: 24th Nov 2013, 08:39 -
Premiere Pro ignores surround channels in 5.1-channel wav
By Asterra in forum AudioReplies: 14Last Post: 11th Jul 2011, 19:58 -
Convert MKV to WMV w/5.1 channel surround?
By Spdngblt56 in forum Newbie / General discussionsReplies: 14Last Post: 21st May 2010, 02:11 -
6-Channel Wav to AC3 and DTS
By kerpal in forum AudioReplies: 8Last Post: 9th Feb 2009, 10:10 -
AC3 to 6 Channel Wav
By RabidSmurf in forum AudioReplies: 13Last Post: 11th Jan 2009, 12:52
