What's the major different between these two? I know H264 encode/compress HD up to 1080. Can't we use Dvix compression with 1280×720 or 1920×1080 resolution and get the same result or it only goes up to 480i? I asked since a lot of DVD player does not play H264 format as yet.
Results 1 to 13 of 13
Athlon II X2 2.9Ghz
4G ram, 500HD, Dual Boot Win7_64 & XP3_32, ATI HDTV WONDER -
Good question. Short answer - Divx is older technology and H.264 is new technology. H.264 takes advantage of some technological improvements in encoding and as a result can deliver better quality at a lower bit rate than Divx. That doesn't mean that Divx is crap, but H.264 is better.
Yes, you can encode 1280x720 and 1920x1080 with Divx. No problem. However, it will take higher bitrate and thus produce larger files to get the same quality as H.264.
H.264 playback requires a lot of processing power and it takes newer and more expensive playback chips to do it in standalone players. Divx doesn't require that much horsepower to decode it, so chips that can do it have been around for years and are pretty cheap to put in DVD players. -
Also note DivX compatible DVD players are usually limited to SD 720x480 or 720x576 in "home theater" profile
As jman98 says, if you use DivX in "unrestricted profile", you will be able to encode 1080p, but it won't play on most DVD players
If you use DivX plus HD profile from Divx 7 , you can use HD (Divx 7 HD is actually a version of h.264, not MPEG4-ASP like the older DivX 6), but there are not very many certified devices (but media players like WDTV, TviX, Popcorn Hour can play it, along with compatible h.264 streams) -
Note that Divx 7 includes both the old MPEG 4 Part 2 encoder (ie, traditional Divx) as well as the new MPEG 4 part 10 (h.264) encoder (the latter only in the Divx converter program and a closed beta CLI encoder) and can produce HD with both.
Originally Posted by poisondeathray
Some Blu-Ray players will play an "AVCHD" version of h.264 but not all.
Some "media players" are less restrictive on h.264, others are more restrictive.
I hope this fully answered your question.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Thanks for all your input.
"Also note DivX compatible DVD players are usually limited to SD 720x480 or 720x576 in "home theater" profile " make sense.
I might just tried 720 resolution Divx and play on my dvd player and see if it plays. This question just came up at work and hard to find time at home to sit down and actually test.Athlon II X2 2.9Ghz
Originally Posted by NautTboy
If the player sells for under $100 figure 720x480/576.
If it sells for over $200 check the Divx certified list.Recommends: Kiva.org - Loans that change lives.
I have the cheap brand. Mostly it is the cheap brand that plays almost everything. I have the RJtech karaoke. It's plays all,(tested) DVD, miniDVD, SVCD, VCD, CD+G, DIVX and JPEG. Of course, not H264 format avi(tested).
Since I don't have HD/BR drive, I will have to download some sample and try to convert to Divx with HD resolution and test it.Athlon II X2 2.9Ghz
Ok, so what is really a 1080p Upconverting/upscale DVD player? If a DVD is able to produce 1080 resolution(HD) and capable of playing Divx, does that mean it could play HD resolution? I would encode it to 1080 or 720 divx, tho I won't get much time on a DVD as mentioned earlier. That's fine, I'm not backing up any DVDs, more of family videos.
I'm kinda confuse, when a dvd resolution is 480 and it mentioned 720/1080 upconverting.Athlon II X2 2.9Ghz
Originally Posted by NautTboy -
Ok, what's the advantages of the upscale let just ask? HDTV has RCA, SVIDEO, Component input, why need the HDMI when you will get what a DVD max anyway.
Athlon II X2 2.9Ghz
For Divx HD certified hardware players look here.
http://www.divx.com/en/partner/certified/oemodmRecommends: Kiva.org - Loans that change lives.
DivX H264 Encoder
By Anakin in forum Video ConversionReplies: 1Last Post: 21st Jan 2012, 14:04 -
DTS OR AC3 to mpeg1/2 4 divx or h264
By DRINGO in forum AudioReplies: 1Last Post: 31st Dec 2011, 11:16 -
divx vs h264
By ecc in forum Video ConversionReplies: 2Last Post: 26th Jul 2007, 07:55 -
Trying to encode DVD to DIVX/AVI or h264
By cassavetes in forum ffmpegX general discussionReplies: 11Last Post: 25th Jun 2007, 10:46 -
mkv-H264 to divx
By vifa84 in forum Video ConversionReplies: 1Last Post: 31st May 2007, 17:28
