Hi,
New to burning dvd. I have a MPEG file (ripped from other region) and I can sucessfully burn it to dvd (nero), but my Sony dvd player says it won't play it because it's the wrong region.
Is there a way to remove region from the file, or is it easier to disable/change region on my dvd player?
Any advise would be appreciated.
Thanks,
Ripped DVDs have no Region Code. Your problem is video format (PAL - NTSC) and there is no easy solution to that problem other than to buy a player that can convert PAL format to NTSC format.
Trouble Burning on DVD Architect
By croonprince in forum Authoring (DVD)Replies: 0Last Post: 6th Dec 2011, 16:46 -
DVD to an edited MPEG-2 file with MPEG audio: Trouble/please help
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 21Last Post: 9th Aug 2011, 08:52 -
Having trouble burning a DVD off of my DVR
By RRFeeney in forum Newbie / General discussionsReplies: 2Last Post: 1st Oct 2009, 14:57 -
Having trouble burning from hard drive to DVD
By becassier in forum Authoring (VCD/SVCD)Replies: 5Last Post: 5th Nov 2008, 12:33 -
Trouble burning/detecting DVD+R DL
By lowdirt in forum Authoring (DVD)Replies: 3Last Post: 21st Sep 2007, 02:23
