Guys
I recently noticed problem with my DVD which I create from Nero or ConvertX When I play in my DVD player it start freeze for couple of secound and play I don't know Is it softwar issue or Hard war issue? Actully I am using Nero and ConvertX for long time I didn't have problem in past so I don't know what's going on I have to figure it out I would appreciate your help in refrence to provide me guideline
Thanks in advance
	What does mean bad media? and How should I use verbatim or taiyo yuden? whar I can find it?Originally Posted by minidv2dvd
	The discs you are using.Originally Posted by Neil_2004
 Best Buy usually carries Verbatim discs, if there's one near you. Otherwise, Meritline.com and Rima.com seem to be two common on-line vendors (I've used Meritline in the past).and How should I use verbatim or taiyo yuden? whar I can find it?
	Do you think Is it possible my DVD player also making problem? because once I play in my DVD player same issue reported in another DVD player so I thought my dvd player damage DVD and it will not recover How do I know my software is doing good job?Originally Posted by Jim44
	You are ignoring the most likely issue, which others have already answered for you. Use either Verbatim or Taiyo Yuden blank DVD discs. (Supermediastore.com is another Taiyo Yuden dealer online.) If the problem still exists, then you can come back here and ask about software, etc. -- but I would bet the use of good media will take care of your problem.
 You never mentioned the brand of blank discs you are using, but by the description of the problem, they are --by far-- the most likely culprit.
 Also, please make friends with punctuation.
	Read the DVD Media Quality Review for the information on the best blank DVD to use:
 http://www.digitalfaq.com/reviews/dvd-media.htmWant my help? Ask here! (not via PM!)
  DVD-RW IssueBy anurse in forum DVD RippingReplies: 1Last Post: 17th Nov 2011, 09:43
  Audio Synching issue in Sony Vegas - What is the best way to solve my issueBy pandeyrajiv in forum EditingReplies: 2Last Post: 19th Dec 2010, 23:53
  K-lite issue then mp4 issueBy Arch3type in forum Software PlayingReplies: 0Last Post: 15th Dec 2010, 11:57
  DVD+RW issueBy codeman in forum ComputerReplies: 8Last Post: 21st Aug 2009, 22:49
  HD to DVD issueBy robjv1 in forum Video ConversionReplies: 4Last Post: 3rd Apr 2008, 05:46
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
