    Aug 2009
    Australia
    Hi all I am trying to copy a VCD and reformatt it to a audio CD format or even a MP3 type of format.
    Any ideas????
    I try and I Thai
    I moved you to your own topic as dvd to mp3 is not same as vcd to mp3.
    Open the vcd.dat file in for example AoA Audio Extractor and convert directly to mp3. If you can't open the vcd.dat then convert the vcd to a mpg using vcdgear first.
    Aug 2009
    Australia
    Thanks Baldrick
    I used AoA Audio Extractor but get the following on the music track
    It seems that there is no video in your file.
    Please waitting ....
    Then it crashes.
    However I have sucessfully converted the opening segment.
    Will try vcdgear now
    I try and I Thai
    Aug 2009
    Australia
    vcdgear worked great and now so does AoA
    You're a genius.
    I'll have to stay around and learn more things
    I try and I Thai
