Hi
Until now I have only made vcd. so I have a question about the quality of svcd. If u make the bitrate so a movie will fit on 2 cd's and with mpeg2 format, the bitrate will be better than with mpeg1, but not the best mpeg2 bitrate.
Is this a way to go or will it just be best to make 3 cd?
I am not sure what you mean. How is the quality of the avi files? :-?
Presume a DVD-ripp as sourse
Mpeg1 (vcd) have a permanet bitrate 1150, and with mpeg2 (svcd) u can use a higher bitrate and improve quality. If u use max bitrate for mpeg2 u will have u use 3 cd's.
So what I mean is;
Is the quality MUCH better with a bitrate configurerd to fit on 2 cd with mpg2 than a regular vcd (mpeg)?
The bitrate is encreased e.g from 1150 up to 1700-1800....
regards -
you will always be able to fit 40.5min per disc(cbr) if you adhere strictly to the svcd spec. 50min per disc(vbr) is reasonably acceptible even for a 29.97fps full-screen source. you can push 60min per disc(vbr), but you need a 23.976fps+pulldown widescreen source to even hope for acceptible results & i'd recommend replacing any original letterboxing with new 0,0,0 black bars
VCD to DVD (not SVCD)
By noyou in forum SVCD2DVD & VOB2MPGReplies: 20Last Post: 19th May 2009, 17:56 -
How to make a VCD/SVCD with CD Audio (CDDA)
By Baldrick in forum User guidesReplies: 74Last Post: 24th Dec 2007, 19:37 -
Beeping on vcd/svcd
By mgdt in forum Newbie / General discussionsReplies: 5Last Post: 20th Dec 2007, 11:56 -
avi to vcd/svcd
By neynme in forum DVD RippingReplies: 7Last Post: 26th Aug 2007, 21:25 -
How to copy-protect a VCD/SVCD v2.0
By Sine29 in forum User guidesReplies: 23Last Post: 20th Jul 2007, 11:27
