People I have a avi file and I need to convert it to quicktime mov format ir to .wmv format so I can upload it at a site. Site only accepts quicktime or .wmv. How can I do this? Thanks.
Which computer/OS are you using? There are a number of converters that can do this. But, if you're using XP/Vista, you should probably have Windows Movie Maker handy - that should be able to encode the AVI to WMV, I believe.
If cameras add ten pounds, why would people want to eat them? -
I think Windows Media Encoder may work under Win98... can't remember if I did have it installed on one of my Win98 towers. You might also give WinFF a try. SUPER may or may not work, but I don't really recommend it at the moment. Any GUI encoder that uses ffmpeg or mencoder may work under Win98 - I can't be sure, though. If you're not against using command-line interfaces, you can always try using ffmpeg or mencoder directly, to encode to either Quicktime or Windows Media.
Yeah, but the latest versions of AVIDemux won't work under Win98, more or less. I ran some experiments on more than one version of the setup packages a while back for another topic, here... don't remember which topic, though.
You might also want to take a look at Quick Media Converter. I've used it on my win98se machines in the past. At least it's free, so it will only cost you time to try it out.Originally Posted by capman21
Format Factory should be able to convert to WMV and MOV under Win 98.
I haven't tried it myself under Win 98 (man who uses this anymore...
), but I see this in their website: "OS requirements: All 32 windows OS".
Problem Converting AVI (DV) to MOV (DV)
By Casho in forum Video ConversionReplies: 3Last Post: 15th Feb 2011, 05:27 -
converting avi to mov
By thecrock in forum Newbie / General discussionsReplies: 2Last Post: 23rd Feb 2009, 15:31 -
Converting MOV -> MPEG-2 (or AVI or...)
By Sean-PH in forum ffmpegX general discussionReplies: 5Last Post: 10th Jan 2008, 13:35 -
converting to avi or mov
By scarlac in forum DVD RippingReplies: 1Last Post: 25th Jul 2007, 07:00 -
Converting .mov or .avi to DVD
By webstar in forum ffmpegX general discussionReplies: 5Last Post: 6th Jun 2007, 23:56
