I am having problem with playback sound on DVD movies. All sounds are reproduced with the exception of speech.
Playback of titles on BBC iplayer, error of missing direct speech is not applicable and all background sounds are reproduced.
I have tried two DVD playback software and this applies of no "speech" comming from the people mouths.
As I am receiving back ground sounds, and normal reproduced speech from other sources ie BBC iplayer, I presume that sound card is correctly functioning.
Any suggestions to rectify this error will be most appreciated - sincere thanks.
All speakers connecting wires have been checked over, and connected to correct sockets.
	You probably don't have a center channel speaker but you have windows configured to use a center channel speaker. Go to the audio setup applet and configure your speakers correctly.
	Possible problems:
 1) You are receiving only rear-speaker audio of a surround-sound audio stream;
 2) You are having phase-cancellation issues in the frequency range of human voices;
 3) You have lost your hearing in the frequency range of most human voices;
 4) You are playing a non-commercially-released DVD that is defaulting to a "mix & effects only" soundtrack stream (a mix usually available only for creating foreign-language versions of a movie).
 or...
 5) You are overmedicated.
 How many DVD movies are affected? Usually, most audio mixes have voices on every track--the possible exception being the rear channels of a surround sound mix.
	filmboss80, I presume that most of your suggestions, are tongue in the cheek humour!
 1. All speakers 5.1. Speakers are all producing sound.
 2. Not clear.
 3. My hearing is very good.
 4. All DVDs purchased from registered retailers. All produced sound and speech before error started.
 5. I am not a "junkie" or ever have been.
 Since error started, over twenty and still counting.
 jajbo, my set up is for 5.1 speakers.
 Speakers are all functioning correctly, except when using DVDs.
	Yes, I like to inject a bit of humor into my posts whenever possible. As for your problem, I am at a loss, except for the possibility of phase cancellation. If you don't understand what I'm talking about, perhaps you can do a search on the subject. Even if that were the case, I couldn't tell you the cause.
 Check out this link: http://www.videomaker.com/article/12246/
	If there is truly no speech (not just low-volume), perhaps your disc has a separate "soundtrack only" option. I've come across a couple such discs that were authored to default to the soundtrack-only option. Manually selecting a different audio track solved the problem.Originally Posted by BobbyScot
 And if that doesn't work, and you are not currently on medication, then the solution is to start.
	Maybe you got a simulated matrix switch turned on which cuts out the center channel? I think,therefore i am a hamster.
	This web site has a simple 5.1 test file that might help:
 http://www.lynnemusic.com/surround.html
 It's simple voice prompts that say "Front left, center, front right, rear left, rear right". Each prompt is supposed to come from the corresponding speaker.
  Fixed sound synch in part of video but now how do I recombine everything?By johnharlin in forum EditingReplies: 0Last Post: 12th Sep 2011, 21:56
  Please Help! DVD rip with surround sound playback?! Is it possible?!By Gatlinator in forum DVD RippingReplies: 6Last Post: 12th Dec 2010, 20:12
  how can i edit a small part inside a movie and make that part look bigger?By xxquatroxx in forum EditingReplies: 1Last Post: 24th May 2010, 16:32
  TMPGEnc cannot open the video part of the file, only the audio part can.By dzsoul in forum Authoring (DVD)Replies: 15Last Post: 3rd Apr 2009, 09:36
  Music sound playback is greater than word sound playbackBy shknoll in forum Newbie / General discussionsReplies: 0Last Post: 31st Aug 2008, 14:09
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
