I just can't seem to get TMPGenc. to read the .d2v file created with DVDx. I read something aboute Raising the nummer on the VFAPI plugin in TMPGenc. but how do I do that. I know where the are but can't change the settings. I have TMPGenc 2.5 now. with earlier versions of TMPGenc I have the same problem. Because of this I created an .mpg with DVDx itself but the quality is poor.![]()
This is answered many times. Search the forum and / or have a look at Sefy's ripping guide. Both dvd2avi and TMPG need the proper vfapi plugins, that must be registered.
Are u sure u got the complete file?
I had this problem and it was because the disk was out of space!
Therefore the file was unreadable.... -
Make sure you download ALL 3 components: TMPGEnc / TMPGEnc VFP plugin and DVD2AVI.
Then, unzip all 3 ZIP files into the SAME (emphasize SAME!) location! and then run the TMPGEncVFP_Install and then you will be able to open D2V files.Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician.
Camcorder doesn't read SD card!
By Dawood1987 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 17Last Post: 14th Apr 2014, 06:25 -
So i have a problem - 1.30 GB or more movie doesn't read to end
By otakumano in forum DVD & Blu-ray PlayersReplies: 25Last Post: 10th Apr 2012, 08:10 -
VirtualDub D2V file error
By Dr.Who in forum Video Streaming DownloadingReplies: 5Last Post: 17th Dec 2010, 14:23 -
ac3gain doesn't read vob.ac3
By volam in forum AudioReplies: 12Last Post: 15th Mar 2008, 11:53 -
DGMPGDec plugin for AVISynth doesn't read MPEG file's audio
By Mark001 in forum Video ConversionReplies: 11Last Post: 9th Jun 2007, 18:07
