    Aug 2009
    All,
    Does anyone know of a good program to convert DTS to AC3? I've tried meGUI and besweet and I can't get either to work.
    In megui, I can add the input .dts, set the decoder, add it to the queue, but when I start it, it shows 'error' in that queue status. I havent' been able to do anything with audio in megui. I wish i could because that program is awesome for video.
    I tried besweet, but I can't get the gui to start. it says it's missing a .dll, but that file is not present in either the gui or the program folder.
    suggestions?
  2. DECEASED
    Jun 2009
    Heaven
    How about eac3to
    Aug 2009
    Hi,
    I just tried that one and it works. Thanks. I have a question about eac3to if anyone knows. I used this command:
    eac3to 00013.dts 00013.ac3 -640
    The source has 5.1 channels. does this program keep all the channels by default?
    canada
    Yes.You have to use extra commands to downmix the channels.You can also get the gui and see all the options.
